1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
newbie with a no start problem
Old Jun 20, 2010
justa d16z6's Avatar
justa d16z6 is an unknown quantity at this point
To start I am new to the whole Honda/import scene. I purchased this car to use as a daily driver for gas mileage. The car is a 95 Honda civic ex coupe with the d16z6 1.6 vtec engine and automatic trans. I purchased the car with a bad engine and bought a replacement out of a 94 del sol. It is also a d16z6. I have pulled the old engine and installed the new one to find that it won't start. It is turning over but it won't fire. The strange thing is that it is getting both fuel and spark. That would leave me to believe that is either the crank or cam sensor. Being new to these my search reviled that the crank sensor is in the distributor? I used distributor off of the civic engine because it was just replaced not that long ago. Do these engines has a cam sensor? I am out of ideas. All the vacuum lines are connected. I just want to see if I may be missing something due to my inexperience. Thanks in advance for any help.
Old Jun 20, 2010
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Re: newbie with a no start problem
When you install the dizzy make sure you put it in the right way. Those Civic dizzy's can be installed 180deg off.
also check your fire order on the plug wires. those are the main 2 causes when replacing a motor that I see people have.
Tim1959
May 10, 2015 03:56 PM
black2k1vtec
Dec 6, 2001 09:49 PM
GabberHead
Nov 20, 2001 07:32 PM
OoSiLvErCiViCoO
Nov 14, 2001 11:35 AM
OoSiLvErCiViCoO
Nov 14, 2001 06:21 AM
