cylinder 2 missfire code P309
Old Jun 16, 2010
wdeguire's Avatar
wdeguire is an unknown quantity at this point
what do you think would cause a cylinder 2 missfire code? do i just need new wires?
Old Jun 16, 2010
wdeguire's Avatar
Re: cylinder 2 missfire code P309
actually the code is p 0302...help would be appreciated. thanks
Old Jun 16, 2010
there's a lot of things that could cause a p0302.. bad spark plug or bad wire are in that mix..
From searching you don't own a 7thgen civic, so you should prolly post what kinda car you have since you decided to post in the wrong section. a 96cx, from what I could tell by searching?
clicky---> http://www.obd-codes.com/p0302
Old Jun 16, 2010
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Well if we are talking about a D16 not a D17 then
Bad plugs
Bad wires
Bad Dizzy
Bad Inj
Bad piston rings
Leaking Valve seals
Have fun
Old Jun 16, 2010
wdeguire's Avatar
sorry, its a 98 civic hatchback 1.6l.. ive since cleared the code and driven it for a while checked it for the same code but nothing....hmm
Old Jun 16, 2010
CrewChief's Avatar
It happens. If it comes back then worry.
Old Jun 16, 2010
wdeguire's Avatar
thanks everyone
mistermenphis22
Jul 13, 2015 04:43 PM
Dobber1
Jul 10, 2015 11:17 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
WhosYoDadday85
127
Apr 5, 2008 06:58 PM
