cylinder 2 missfire code P309
Re: cylinder 2 missfire code P309
there's a lot of things that could cause a p0302.. bad spark plug or bad wire are in that mix..
From searching you don't own a 7thgen civic, so you should prolly post what kinda car you have since you decided to post in the wrong section. a 96cx, from what I could tell by searching?
clicky---> http://www.obd-codes.com/p0302
Well if we are talking about a D16 not a D17 then
Bad plugs
Bad wires
Bad Dizzy
Bad Inj
Bad piston rings
Leaking Valve seals
Have fun
Bad plugs
Bad wires
Bad Dizzy
Bad Inj
Bad piston rings
Leaking Valve seals
Have fun
mistermenphis22
Jul 13, 2015 04:43 PM
Dobber1
Jul 10, 2015 11:17 PM
WhosYoDadday85
127
Apr 5, 2008 06:58 PM
