How do you install headlight bulbs?
Old Apr 19, 2002
Civic2001's Avatar
Civic2001 is an unknown quantity at this point
I just got some HID H4 bulbs, and want to install them, but not quite sure how to do it. I looked and there is a little plug right behind the light, so I unplugged that and then there is this big rubber piece. How do you get that rubber piece off? I tried pulling and twisting it, and its not much room since its right by the battery and on the other side the fluid stuff is in the way. How do you install these bulbs?
Thanks
Old Apr 19, 2002
Decamo's Avatar
Decamo has a little shameless behaviour in the past
The instructions are in your owners manual. You know that book in the glove compartment? [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Apr 19, 2002
Civic2001's Avatar
Thanks, I didn't even think about that. [IMG]i/expressions/face-icon-small-blush.gif[/IMG]
Old Apr 19, 2002
VNlilMAN's Avatar
The Standard One
just pull that plug off, take off the rubber thing, unclip the metal thing take out the bulb, replace it(dont touch the bulb with fingers, use a towel or something), put everything back together.... the driver side one, just pull the water thing up n it should come off n give you more room to work with
Old Apr 19, 2002
Blznweels's Avatar
Blznweels is an unknown quantity at this point
read your owners man, but heres a crash course
1. Pull black plug off of the back of the bulb
2. pull rubber gasket off...its a friction fit, grab the rubber tabs facing back of the car and pull
Now you should see the back of the bulb, there is a wire braket holding it in...
3. Put your finger right above the bulb push wire braket in and slide to your left, braket should flip down
4. Pull out the bulb
5. Put in new Bulb DONT TOUCH THE BULB make shure it dosnt touch anything going back in
6. Flip up braket slide to right
7. Push on gasket, make shure 3 bulb prongs are through the center hole
8. Push on plug
Behind the right bulb there is a white canister with rubber hoses in your way, you can pull this strait up to move it out of your way for easier access.
Old Apr 19, 2002
Civic2001's Avatar
Thanks guys, I installed them. Looks great!
Old Apr 19, 2002
SatinSilver2k1's Avatar
SatinSilver2k1 is an unknown quantity at this point
no one even flammed this guy!
haha
Old Apr 19, 2002
genterara's Avatar
genterara is an unknown quantity at this point
I'm surprised about the lack of flaming
*locked*
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
bsmiley
Apr 27, 2015 01:27 PM
0100010
Aug 6, 2008 09:22 PM
SWEETRIDE
Nov 27, 2001 05:52 PM
aZnVoYCe
Nov 15, 2001 04:48 PM
