Looking for aftermarket headlights that take 9005/9006 bulbs. But for an 03
I'm looking for aftermarket headlights that will fit on an 03 civic that take the 9005/9006 bulb combination.
The 04-05 headlights take the bulbs but won't fit an 03 I don't think.
Anyone know any that do?
Re: Looking for aftermarket headlights that take 9005/9006 bulbs. But for an 03
doesnt exist. all the 01-03 aftermarket headlamps take H1 or H3 bulbs and they all suck for light output. i have pics if youre interested. if you want to go aftermarket, you should swap out the projector unit with a better one from oem car like audi, mercedes, etc. halogen or hid depending on your preference.
Is there an auxiliary lamp that takes 9005/9006? I've checked all of hella's stuff and can't find one.
yeah there is a projector lamp on ebay called P1 which you can order in 9005 size (and then fit HIR into it). but i have no idea what the output is like. HIR with catz zeta is basically brighter than most HID lo beam setups. if you really need tons of light and have a somewhat big budget, the hella xenon HID driving lights are the best you can buy but they cost well over $500. check rallylights.com for a huge selection of hella products. the "modules" section has all the projector type stuff and fog lamps.
heres the ebay P1 i mentioned. if you get them post some pic, im curious about what kind of output it has.
http://cgi.ebay.com/ebaymotors/UNIVE...Q5fAccessories
Thanks for the info, can't afford the hella xenon HID driving lights, but I might look into those P1s.
It would be a gamble though as to which is brigher:
1. High beam zeta boosted philips XP X-treme power +80 bulbs
or
2. Normal high beam phillips +80
and zeta boosted HIRs in those ebay P1 fogs
Whatever I end up doing I'll definitely post up pics
or
the oem h4 hi beam is terrible with or without boost. i would definately go for the driving lights. even with just hir and no catz zeta, they will be very bright. those p1 are fogs i believe, so you would have to open them up and remove the metal cutoff shield to turn them into driving lights (basically a supplemental hi beam).
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
