Can anyone let me know how exactly to shave my "Civic" emblem off?? DIY link is not workin
Old Apr 18, 2002
03Eclipse's Avatar
03Eclipse should not be trusted03Eclipse should not be trusted03Eclipse should not be trusted
Can anyone let me know how exactly to shave my "Civic" emblem off?? DIY link is not working.......
Thanks......[IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/face-icon-small-smile.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Apr 18, 2002
FLiPpIeS's Avatar
FLiPpIeS is an unknown quantity at this point
take a blow dryer and blow dry the emblem till the glue gets softened up. then after u do that for a couple minutes slowly peel the emblem off. then wutever glue is left jus rub it off with a wet rag and there u go
Old Apr 18, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
Use floss or fishing line to peel it off.
Old Apr 18, 2002
eProdigy's Avatar
eProdigy is an unknown quantity at this point
take any chisle and place it between the emblem and your car, hit it really hard on the top it will slid down the car about an inch and loosen the glue. then hit it on the side intil it moves off the back of your car and falls off. take a rag of glue-off and whipe off the remaining glue. works well and takes about 10 minutes to do.
Old Apr 18, 2002
03Eclipse's Avatar
sweet - thanks flippies -
Old Apr 18, 2002
pakman313's Avatar
pakman313 is an unknown quantity at this point
just keep flossing it like crazy hehe
Old Apr 18, 2002
fraga's Avatar
Wicked Moderatuh
eProdigy, WTF. DO NOT LISTEN TO HIM. A chisle, are you nuts, your gonna fawk up the paint job. Just use some heat, and the glue loosens up, then either peel it off or use something like floss or a string to slide behind it. Then, scrub off the remaining glue. Wash and wax. Chisle, you must be out yo damn mind.
Old Apr 18, 2002
03Eclipse's Avatar
got it off = thanks again [IMG]i/expressions/beer_yum.gif[/IMG]
Old Apr 18, 2002
EHouse's Avatar
EHouse is an unknown quantity at this point
LOL@ CHISLE!
Either you have dentist- like hand coordination or an evil sense of humor-
LOL
A Chisle... hehehe [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Peace
Old Apr 19, 2002
Wanger's Avatar
Wanger is an unknown quantity at this point
might as well tell him to wack his **** at it for an hour chisle [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Apr 19, 2002
RevHigh's Avatar
RevHigh is an unknown quantity at this point
for me the glue was a b*t(h to remove, but I had sum 3M adhesive remover, which helped a lot. really easy to do, and really looks good afterwards. [IMG]i/expressions/face-icon-small-cool.gif[/IMG][IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Apr 19, 2002
WD40's Avatar
WD40 is an unknown quantity at this point
* I've found that a can of WD-40 and a lighter works really good. Make sure to use the little red hose. Then strike a flame with the lighter and hold it about 2 inches from the emblem. Spray the WD-40 at the flame so that fire shoots at the emblem. After about 20 seconds the emblem will curl, melt and peel off. Any residual glue will be easily rubbed off because the unburned WD-40 will have softened it up.
Happy shaving!
*Author will not be held responsible for any damage done to your vehicle of you take this advice.
Old Apr 19, 2002
DC5@EM2's Avatar
DC5@EM2 is an unknown quantity at this point
no you guys got it all wrong. What you do is heat the car up to about 3000 degrees celicus, and then remove the car from the emblem. Then you take the emblem and wipe all the rest of the glue from it and then throw your car away.
Old Apr 19, 2002
Blk4blk2K1's Avatar
Retired Super Mod and STILL Pimpin' Yo Mama
Blk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to beholdBlk4blk2K1 is a splendid one to behold
<< eProdigy, WTF. DO NOT LISTEN TO HIM. A chisle, are you nuts, your gonna fawk up the paint job. Just use some heat, and the glue loosens up, then either peel it off or use something like floss or a string to slide behind it. Then, scrub off the remaining glue. Wash and wax. Chisle, you must be out yo damn mind. >>
Use 1 part Gillette
2 parts Mach 3 razor
and a pinch of canned elbow grease...
Should take 10mins or so...Let stand 5 mins to have yourself a glance..
Old Jul 6, 2002
DaCurryman's Avatar
DaCurryman is an unknown quantity at this point
I'm thinking of shaving my emblems, but I want to relocate my CIVIC emblem. once I get it off the current position, what kind of prep to the emblem and glue do I need to re-adhere it to another part of the car. (I'm thinking of moving it to where the "H" symbol is right now)
Also can someone explain to me how I should go about filling in the two holes where the "H" is right now. I read somewhere about using "bondo". Can someone tell me what that is and how permanent it is. Like if I wanna put the "H" back on later...am I just screwed? Thanx again.
Old Jul 6, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Check this out..
http://www.7thgencivic.com/forum/mes...th%20of%20mods
To reattach the emblem, just take off all the existing glue, and use some 3M Emblem glue. Can find it at AutoZone and probably any other local auto store. The glue does get a little stringy so you suggest applying it on a something else to see what it does. Your holes question is further down the above thread.
HTH
-Kre
UltraHDGames
Jun 8, 2016 05:16 PM
rovafa2002
Sep 28, 2015 06:57 PM
General DIY
Sep 25, 2015 08:02 PM
speedlever
Sep 24, 2015 07:18 PM
beanhead
Sep 24, 2015 12:04 PM
