ECU and air pods problems...info needed
Old Mar 8, 2010
Benny88's Avatar
Benny88 is an unknown quantity at this point
hey is it true if u put on a high flow pod filter, it can mess around with your ECU??
confusing the engine with the different amounts of air intake??
if so can anyone point me in the right direction to fix this problem
Old Mar 8, 2010
Saroset's Avatar
Saroset is an unknown quantity at this point
Re: ECU and air pods problems...info needed
The theory I heard is that the less encumbered air is moving in larger, slower quantities. The ECU perceives this as denser air and therefore takes less of it in which throws off the air to fuel ratio. I'm not actually sure if this is a real problem or one of those supposed problems that people pass around when talking about cars.
Old Mar 8, 2010
sureshot1979's Avatar
sureshot1979 is an unknown quantity at this point
its the map sensor that throws the ecu off how to check it easy.....first if your c.e.l comes on get a code reader if it says code error or give you a number check to see if the number adds up to one of the sensors if its your air flow sensor then its your map sensor problem solved disconnect the battery for 15 seconds re connect and bingo the cel will go off
Old Mar 8, 2010
the map sensor should be good for richer air and 5-8 psi without throwing codes
Old Mar 8, 2010
get a synapse valve for the map sensor its a peice of metal that goes on your map sensor keeping the map sensor from dettecting boost or denser air
Old Mar 8, 2010
Benny88's Avatar
cheers guys, thanx for the help!!
to b honest i didnt think it affected it, but my previous car no longer works, and some ppl think it because of that.
so hopefully this is da valve u talkin bout
Old Mar 9, 2010
yes that looks right just make sure you put o ring in the right place
Old Mar 12, 2010
Its called the missing link by synapse
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
jc33312
May 12, 2015 03:17 PM
Bigdaddy198
Apr 30, 2015 08:36 PM
carid
Apr 30, 2015 07:00 AM
Myredjonda
Apr 14, 2015 07:00 PM
