1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1990 honda civic d17zc
Old Mar 6, 2010
civicivic90's Avatar
civicivic90 is an unknown quantity at this point
ok i have a 1990 civic, it started up fine but when ever i give it gas it shuts off... what would cause this, i am leaning toward the fuel pump but im not sure, can anyone help me?
Old Mar 6, 2010
89CRX's Avatar
89CRX is an unknown quantity at this point
Re: 1990 honda civic d17zc
fuel pump sounds like a start also check the throttle cable to see if any play or if it is tight. this problem should be easy to fix provided your a good trouble troubleshooter.
Edit*** the more i thought about it the more i thought of different things that could cause it. try checking your O2's and your CHTS. even give the MAFS a look over and hit it with a multimeter. or check your IATS if you have one. if i were you i would check every sensor thats fuel / air ratio related. also check your relays etc. shouldnt be too hard to figure it out once you give it a good looking over. Gl with the trouble shooting
Old Mar 6, 2010
well this will be the second ef i have owned, and i rebuilt the first one. but i have never run into this, but im going to change the fuel pump and see where that leads, it never hurts to have new parts...
jessicakaybby
Apr 20, 2015 12:11 PM
