Hood release lever broke
Old Jan 9, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
I have a 96 ex coupe, and this morning pulling on my hood release level broke off. Has this happened to anyone else?
I looked up the part at look like it part of cable assembly going up to hood, I assume the whole assembly has to be replaced?
Old Jan 9, 2010
dnice78's Avatar
dnice78 is an unknown quantity at this point
Re: Hood release lever broke
can you open it with a vise-grip?
Old Jan 9, 2010
yeah just cut the plastic off until you see cable and pull that.
Old Jan 10, 2010
civicpapi's Avatar
Yes, I can use pliers. Looks like the whole assembly will have to be replaced, which looks like a pain.
Old Jan 10, 2010
Nosepicker's Avatar
Nosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the roughNosepicker is a jewel in the rough
I'm glad you're asking this question because this happened to me last weekend. I looked up the part number too and it looks like you have to buy the whole cable just to replace the stupid plastic part at the end.
I'm think of hitting up the junkyard and seeing if I can just take off the plastic part. If not, what a PITA this will be.
Old Jan 10, 2010
civicpapi's Avatar
The part is cheap, just the labor involved to replace it is the problem. You might have to remove the fender and the front bumper since that is how it might be run.
Pliers route might be the easiest lol.
Old Jan 10, 2010
the fender prolly doesnt have to come off, the bumper and fender well plastic (splash shield) will for sure. and then taking apart the hood latch and parts of the interior. what a problem
Old Jan 10, 2010
CivicAK's Avatar
CivicAK is an unknown quantity at this point
i had to do this, my idiot boss ripped on the handle breaking it off, Its a pain, you have get into the wheel well, take off the shield, its not complicated, just a waste of an hour of your time.
Old Jan 11, 2010
Nosepicker's Avatar
Can't believe no one's done a write up. Yeah, don't ask me to cuz I'm too lazy. LOL!
Old Jan 11, 2010
ScottDR's Avatar
ScottDR will become famous soon enough
I actually broke mine once when my hood was coated with an inch of ice. I pulled, nothing happened, pulled harder and broke the handle end off. Pliers works fine but the fix is simple. Just remove enough of the inner fender liner clips to access as gearbox mentioned, then loosen the top of the radiator and top of the condenser (if you have a/c) and unbolt the latch. This is done so you can move them back enough to sneak a hand into the opening and feed in the new cable (once the clips are released from the top of the radiator support). Just be mindful of where the old one routed.
Hope that made sense, I just woke up :P
Old Jan 12, 2010
Acidsniper's Avatar
Acidsniper is an unknown quantity at this point
I had this happen in my 97 EX Coupe.
I got a brand new one from RockAuto.com for $10.
It was pretty easy to replace since it comes with the whole assembly.
Old Jan 12, 2010
civicpapi's Avatar
briefly, can you explain what is involved?
Old Jan 12, 2010
Acidsniper's Avatar
I'll do the best I can from memory... There was a bolt or two where the lever was that I had to remove as well as I had to take off the inner fender liner and I had to remove the upper supports for the radiator and condenser so they could be pushed back out of the way. After that it was just a matter of unscrewing the cable from the hood release and running the new cable in it's place.
It's not hard, took me about an hour and a half. I'd consider my skill level to be around a skilled DIYer. My best piece of advise is to run the new cable as you take the old one off, that way you have it all lined up right.
Old Jan 12, 2010
civicpapi's Avatar
I am curious the running of the cable is it clipped as it runs down the fender to the hood or just routed around, also did you have to remove the hood release off the car?
Old Jan 12, 2010
Acidsniper's Avatar
Mine was clipped in along the way at various points. I didn't have to remove the hood latch under the hood which made lining up issues non existent. That's why I removed the upper supports of the radiator and condenser so I could push them back.
Old Jan 12, 2010
yeah if you can avoid it, do not touch the latch. it will be a pain to adjust it again so the hood closes properly.
Old Jan 14, 2010
ScottDR's Avatar
In case you do remove the latch (seemed easier to me as I couldn't see how the cable attached), be sure to mark it before removal. That's what I did and easily put it back in place.
Old Jan 22, 2010
toy4two's Avatar
toy4two is an unknown quantity at this point
hah mine broke off too. I just grab whats left (nub) when I need to open the hood.
Old Jan 26, 2010
metalxmania198's Avatar
metalxmania198 is an unknown quantity at this point
the same has happened to my 97 DX. if anybody goes to fix it and has patience, a proper write-up on the the fix would be tight.
Old Apr 4, 2011
akihiro_16's Avatar
akihiro_16 is an unknown quantity at this point
Hey guys, I had the same thing happen and I have a solution check out the link.
https://www.civicforums.com/forums/2...ml#post4528885
Old Apr 6, 2013
ClaytonKimball's Avatar
ClaytonKimball is an unknown quantity at this point
Re: Hood release lever broken
This is kind of ghetto, but an easy fix. I bought a $1.78 lug from the Home Depot electrical section.
Cut away enough plastic to slip the lug over the metal rod in the release cable. Tighten. Then attach some kind of pull. I used a keyring ($.97 for a package by the key cutting station at Home Depot).
ID:	84971   Click image for larger version
Old Apr 6, 2013
dnice78's Avatar
Not bad!
Old Apr 8, 2013
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
LOL yes. I've just been using pliers but that is great.
Old Apr 27, 2013
puyen's Avatar
puyen is an unknown quantity at this point
Just replaced mine today. Required $17 for the part and two hours of my time. Remove the front bumper cover. No need to remove the fender. Just remove the splash guard. The process should be straight forward. Let me know if you have questions.
Old Apr 29, 2013
Congratulations on doing it right.
Let's just hope the plastic latch on yours doesn't break again! Inherent weakness in the design, I think I'll do the redneck method if I ever do anything.
EDIT: I fixed mine today with a Thomas & Betts splicer reducer, max: 1/0 STR, min: 14AWG wire, barcode 7 83786 37248 5. It was easy except for trimming the plastic because I kept the plastic in place as I was trimming.
ID:	85127   Click image for larger version
mgrantaz
General
May 2, 2022 05:40 PM
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
emiixo
Exterior
Sep 22, 2015 03:53 AM
nixyfior
Sep 14, 2015 08:32 PM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
