Runs rough in 1st and 2nd then fine after that
Old Nov 2, 2009
Tegetus's Avatar
Tegetus is an unknown quantity at this point
Hello all,
97 civic with manual and 4 banger. I'm helping a friend out. His civic runs rough and has no power in 1st and 2nd, but then is fine for the other three gears. Code came up as a multiple cylinder misfire. I'm going to work on it this weekend hopefully. Anyone run into anything similar? I'm thinking vaccum lines, but would that affect a manual tranny? If it was fuel, intake or exhaust, it would just suck across the board. Let me know your thoughts....
Old Nov 2, 2009
Re: Runs rough in 1st and 2nd then fine after that
misfires are usually caused by fuel delivery issues (like clogged injectors), bad or incorrect spark plugs, or faulty/cheap ignition system components like cap/rotor/wires. make sure you are using quality parts. last resort is blown headgasket from coolant leaking on the plugs and causing the misfires.
Old Nov 2, 2009
Tegetus's Avatar
I agree, but the only thing is that the motor runs just fine in 3rd 4th and 5th gear. If it were any of the problems that you listed, then there would be issues across the board. The misfire code probably has been thrown by something else. Is there some type of vaccum line that is affected by what gear that you are in on a manual tranny?
Old Nov 2, 2009
vacuum issues are possible if there a small leak. i would check for cracking esp the ones near the throttle body.
Blazz
Jun 4, 2015 01:04 AM
Allecr3
May 22, 2015 01:24 PM
ywgflyer
May 15, 2015 05:05 PM
crowtoo
May 11, 2015 06:50 PM
supercivic01
South
Nov 30, 2001 11:27 AM
