Honda parts for sale
Old Sep 27, 2009
approb18ct's Avatar
approb18ct is an unknown quantity at this point
All,
I have the following parts for sale:
1. NEW K&N Filters HP-3001 (36) $8 each
2. NEW HANS Head and Neck Support (Small) $750
3. Used GSR distributor (factory) modified for use with Accel DFI Gen 7. Comes with Crane Cams distributor cap and premium Crane shielded spark plug wires (BO)
4. Used Innovative boost controller
5. AEBS spark plug wire covers in matte silver (3 – 1 new, 2 used) $75 each or BO
6. NEW JE Pistons flat top custom pistons (4 sets) $300 each
7. Used Apex Integration Electro-luminescent gauges (6) - 2 temp, 2 pressure, 1 boost, 1 EGT with 6 power harnesses, 1 temp harness, 1 pressure harness and no connectors
8. NEW Custom RAM twin 8-inch slipper clutch with 2 spare disks; paid $5,000; email for more info
9. Used Crane Cams HI-7 ignition w/LX92 performance coil and Mallory capacitator (2 ignitions and coils) $200 each
11. Used Accel DFI Gen 7 (2 - 1 with harness and 1 without); harness for Honda 4-cyl B-series; $1,000 with harness; $400 without
12. Used AEBS cam gears (4) $125 in purple
13. NEW Eagle Cranks 4340 for GSR (2) $500 each
14. Turbostart 16 volt charger for sealed battery $150
15. Z10 Wet Sump Oil System for B series (cost $1800 new) with oil pan; breather with vaccuum regulator; oil filter relocator; block off plates; brackts; oil drive pulley, etc. BO
16. Used Penske shocks (2) fully double adjustable
17. Autometer 17 channel datalogger with 7 bus cables; arm switch; single access accelerometer; 4 EGTs; 2 pressure sensors; parallel/serial converter; 2.25 drive shaft ring; clutch input; 22-pin weather pack $3,000 or BO
Please email me at approb18ct@gmail.com if interested.
Thanks,
Angela
Old Dec 8, 2009
spoonswap91's Avatar
spoonswap91 is an unknown quantity at this point
Re: Honda parts for sale
will you take the pistons for trade?
usajags84
15
Aug 19, 2015 03:12 AM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
jessicakaybby
Apr 20, 2015 12:11 PM
eXNBP
Dec 9, 2001 12:32 AM
