1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
B18C into a 95 coupe! HELP!
Old Sep 23, 2009
nano1589's Avatar
nano1589 is an unknown quantity at this point
Hey!! im new to the honda game! i bougth a 95 civic coupe w a ls 97(obd2) on it. Now im thinking of a GSR 95(obd1) , i think that the swap wont be the problem, im thinkink about the wiring.. the ecu.. n the vtec!!! If anyone know any about that n can help me! i will really appreciate!!! thanks!!
Old Sep 24, 2009
ramonjones16's Avatar
ramonjones16 is an unknown quantity at this point
Re: B18C into a 95 coupe! HELP!
Well if your doing the swap by yourself and you have never done one before there might be some challenges.....you will need the jumper harness to convert the obd2 to obd1.....you also will need the engine harness with the new motor....obd 2 non vtec harness WILL NOT WORK for the gsr trust me Ive tried it....size issues you have no problem...b series will all fit in the EJ1 I have one and know this for a fact...I strongly advise that you switch to the gsr hydro tranny instead of keeping the LS tranny...GSr has shorter gear ratios and better acceleration...when you are doing the swap SAVE everything...mounts brackets etc. Because you never know what might go wrong...make sure the GSr is complete dizzy and everything its a pain in the *** trying to find good used dizzy's or alternators...other than the OBD issues there isnt much else you have to worry about if you knwo your way around a car
bmwstar98
Aug 16, 2015 02:28 PM
Snax
Aug 12, 2015 10:23 PM
Curtchuk
Aug 5, 2015 02:14 PM
NROD315
Jul 21, 2015 07:46 PM
Theshwartz35
Jul 17, 2015 11:13 PM
