94 Civic Engine Swap?
Hi, hope someone can help!
I have a 1994 1.5 Civic Coupe and really want to swap the engine for the 2.2 out of a Prelude. Apart from engine/gearbox and loom, what else am I going to need to swap? Like driveshafts, etc?
Thanks guys!
Thanks guys!
Re: 94 Civic Engine Swap?
You will need to change the driveshafts, ecu, new engine mounts, probably the rear axel off the prelude as your going to need discs on the back aswell as the front, and maybe the front suspension as the prelude engine will be a lot heavier and than the 1.5
you dont need the rear axle. you can easly find a integra rear trailing arms and disc break set up i think the years ar 89-94 for the swap correct me if im wrong
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
beneditti
Jan 15, 2016 12:31 PM
BREADFAN
Apr 15, 2015 08:58 AM
