96 Civic Si Oil Problem?
Old Sep 7, 2009
jumbot's Avatar
jumbot is an unknown quantity at this point
Smile 96 Civic Si Oil Problem?
Hello, I got a 96 civic si. that i got off my buddy... i noticed that lately its been leaving small (i believe oil) spot in my drive way. Its about the size of a quater (ever night). I check my oil level, and it seems half way full even tho i changed the oil 3 days ago. I am interested if this should set off alarms and i should dump this car and get a new one, or this is manageble for a while at least a winter. The car does have a leak just before the catalytic converter. Could that be where the fluid is coming from? But honestly the car drives great, no problems with it, dosen't smoke anywhere, great on gas. Just trying to figure out if this should be a concern. Maybe i should put in some lucos product? what do you guys think?
Thank you
Old Sep 7, 2009
ProVic's Avatar
ProVic is an unknown quantity at this point
Re: 96 Civic Si Oil Problem?
i have the same problem
show us a picture where it leaks
Old Sep 7, 2009
could be coming from anywhere, oil pan seal, other engine gaskets, timing belt area, etc.
Old Sep 7, 2009
jumbot's Avatar
ill try to get you guys a pic as soon as i can, kinda hard with out getting the car up in the air. But does that leak have anything to do wiht me losing oil? my mechanic said i need to get a new cat pipe and muffler anyways to pass emissions this year. said its about $400 CAN, sound about right?
Old Sep 7, 2009
well if its an oil leak then yes
Old Sep 8, 2009
04 Honda Civic's Avatar
If your losing oil and there is oil on the ground after u park I believe u have an oil leak lmao..Now you just need to find it, make sure u top off every day or so with oil or you will destroy the motor.
Old Sep 11, 2009
jumbot's Avatar
Thanx guys for all of your help... i took the car in to a mechanic and he found the leak although i forgot where it was, he said it was not that bad and seen worse. So his advice is just to drive the car and the engine in to the ground instead of doing the timing belt right now, and he will jsut install for me an engine from japan that has like 50 000K on it wiht the timing belt at the same time. Sounds resonable for the money i would have to spend for the timing belt now, vs timing belt and a slightly used engine later.
But thanx for the advice guys.
Old Sep 11, 2009
How much is he going to charge you for a new motor. I am almost 100% sure its not worth it. A tb and gasket wont cost you more then $1000 actually it would be around $600ish depending on the gasket a new motor is probably gunna run u at least $1500 or better
Xuhme
21
Aug 7, 2023 03:40 PM
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
Grazzhopper
Nov 11, 2001 08:06 AM
