Alternator Belt Removal 98 Civic
Old Aug 18, 2009
BoostedTT91's Avatar
BoostedTT91 is an unknown quantity at this point
How do u remove the alternator belt on a 98 Civic DX 1.8 5 speed. I see there is a bolt with a long opening to move the alt forward to loosen the belt but what else needs removed? i cant see anything else
Old Aug 20, 2009
sql_civic's Avatar
Re: Alternator Belt Removal 98 Civic
You have to loosen the pivot bolt from underneath and the adjustment bolt from the top bracket.
You can then cut the belt to get it off.
If you want to put a new one on then you have to remove the A/C compressor belt and also the lower engine mount.
CarStuff
Dec 6, 2020 12:52 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
smmahan
Apr 15, 2015 08:17 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
