HID light problem, one light works.
Old Aug 6, 2009
Spiffy_B's Avatar
Spiffy_B is an unknown quantity at this point
I bought a HID kit awhile ago, installed it and everything went well for a few weeks. Then one night i saw that one of my lights were out. I looked under the hood an saw that made ballast hand fell from its spot.
I sent the ballast back, they sent me a slimmer one. Once i put that in, nothing happened, then i thought of a fuse. The fuse was blown, when I replaced that, nothing still. I bought new bulbs (went from 10k to 12k), still nothing. What am i missing? Does anybody have a clue to what I'm doing wrong or forgetting.
Old Aug 6, 2009
fracas's Avatar
fracas is an unknown quantity at this point
Re: HID light problem, one light works.
check and see if you plugged them up.
Old Aug 7, 2009
Spiffy_B's Avatar
Did that too, i did a complete re-install yesterday. I took the front bumper off, took out the headlights to do a headlight restoration. Shrink wrapped the connections and still nothing.
Old Aug 7, 2009
fracas's Avatar
Okay I would do this. Get a voltage meter and have someone turn the heallight switch on and off while you are checking the voltage on the headlight connector. You should have 1 negative, 1 positive for running lights for the blinkers, 1 positive for the headlights when they are on.
Now if you have 12v at the connectors like you should then its not the wiring. I would swap the working hid over to the side thats not working and try it out to see if the light works. If it does then you have a problem still with the Hid unit they sent you.
If you need a New Ballist and H4 Bulb I have one new in the box for $30. This isnt a full kit. I used one of them on my Gsxr. So the other is a extra.
Old Aug 9, 2009
Spiffy_B's Avatar
I was thinking of doing that, i found a volt meter at my job yesterday so ill do it today or tomorrow.
Thanks for the offer but i already bought a new ballast just for the crap of it. $22 and shipped from eBay. It should be here tomorrow. I hope something works out.
Thanks for the help Fracas.
Old Aug 19, 2009
Spiffy_B's Avatar
Ohk, I got a volt meter earlier and came to find out that I am getting power but think the ground isn't grounded so I'll be re-grounding it on Friday when I'm out. I rechecked the fuses and it was still fine.
Old Aug 27, 2009
Spiffy_B's Avatar
IT WORKED!!! I regrounded the negative wire with a 16 guage wire. It is a little bigger and the warranty replacement ballast didnt work still but the extra one i bought did work. I was able to see with one light but now will be even better, later tonight I'll post pics.
Old Jun 4, 2010
marek91's Avatar
marek91 is an unknown quantity at this point
is a relay switch needed to install HID's on a 2000 civic?
Old Jun 7, 2010
Spiffy_B's Avatar
nope, everything you'll need will be in the kit. HID kits these days come as a plug and play kit. My current one has me splicing headlight wires together.
Old Jun 7, 2010
a relay kit isn't necessary, but not a bad idea
Old Jun 8, 2010
marek91's Avatar
okay thanks im not the best at electrical so sorry for the dumb question but what will a relay do? does it just basically control the flow of power and keeps it constant?
Old Jun 11, 2010
Civic23drifter's Avatar
Civic23drifter is an unknown quantity at this point
Originally Posted by Spiffy_B
I bought a HID kits awhile ago, installed it and everything went well for a few weeks. Then one night i saw that one of my lights were out. I looked under the hood an saw that made ballast hand fell from its spot.
I sent the ballast back HID kits , they sent me a slimmer one. Once i put that in, nothing happened, then i thought of a fuse. The fuse was blown, when I replaced that, nothing still. I bought new bulbs (went from 10k to 12k), still nothing. What am i missing? Does anybody have a clue to what I'm doing wrong or forgetting.
A relay will pretty much make it so it doesn't flicker and such.
Linda0818
Apr 23, 2015 11:30 AM
twtron
Apr 17, 2015 12:09 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
disaster
Nov 7, 2001 05:30 PM
