How stiff is your clutch pedal?
Old Aug 2, 2009
mntbiknfool's Avatar
mntbiknfool is an unknown quantity at this point
I recently purchased a 1997 Civic with 82k miles and was surprised at how stiff the clutch pedal was. The stiffness of the clutch is almost comparable to that of the muscle cars I used to drive as a kid! This is a little 4 cylinder...the pressure plate shouldn't be THAT stiff should it!
The previous owner said that both the master and slave clutch cylinders had both been replaced recently. I bleed the clutch today to see if it would help anything and noticed a squeal as the clutch pedal was pressed that appeared to come from within the bell housing. The car has set idle for a while and I am beginning to think that the pressure plate has begun to rust! I mean, the pedal resistance should be proportional to the spring resistance in the pressure plate, correct? So the questions I have are:
1) Is your clutch petal easy to push or hard?
2) Has anyone ever had a similar problem?
Thanks for your time.
Jim
Old Aug 2, 2009
Re: How stiff is your clutch pedal?
Sorry, I guess this is a question about problems with my car. I posted it in another forum. Please excuse my error...
Old Aug 4, 2009
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Jim
Stock civic PP is light. But it sounds like the previous owner put in an after market PP. Some are stiffer than others. Unless it feels wrong, I wouldn't worry about it.
Old Aug 17, 2009
samscivic's Avatar
samscivic is an unknown quantity at this point
I just replaced my master and slave clutch cylinders too..Went from really loose to a lot stiffer, feels brad new and normal for me.
Old Aug 23, 2009
Running Riot's Avatar
^Warranty voider
Running Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of light
Honda is reknowned for world class drivetrains.
At 82k miles I don't see why the previous owner would have used an aftermarket clutch. Unless he is running a spoon engine with t-66 turbos and a Motec exhaust........ sorry...
The squeal is from a dry release bearing its normal. If my clutch gets hot it's spongy and light, if its cool its stiff.I have an exedy stage 1.5 clutch and PP. You can remove the bottom flywheel cover to help keep it cool. I have a stainless clutch line too so it helps make it stiffer too. Honestly your better off with a stiff clutch pedal IMO, easier to feel the clutch engage/disengage.
Stiff is relative too my friend. When you say its stiff does that mean you need EFFORT to push it in? or just minimal exertion?
Try driving it around town in traffic, shifting regularly and see if it gets better. If it doesn't change, hell, let it be unless it's a problem.
i drive
Sep 14, 2015 01:56 PM
violentpanda
Sep 7, 2015 11:49 AM
tommycanada
Sep 5, 2015 04:59 PM
JetsterDajet
Aug 15, 2015 08:07 AM
fordover
Jul 11, 2015 09:10 PM
