(4 civic ex Radiator fan in-op
Old Aug 2, 2009
dbjnky's Avatar
dbjnky is an unknown quantity at this point
My sons car started overheating so i noticed the waterpump leaking which I replaced. Now the radiator fan isnt coming on. I also changed the t-stat. Here is the part I cant figure out. When I test the new temp switch at T-stat housing and I have my test light grounded and probe the green wire the test light comes on and so does the fan? I am not sure whats next. Any help would greatly appreciated.
Old Aug 2, 2009
04 Honda Civic's Avatar
Re: (4 civic ex Radiator fan in-op
Im just taking a guess here, but maybe it could be a bad ground?
Old Aug 2, 2009
rutscivic's Avatar
rutscivic is an unknown quantity at this point
when did you replace the water pump and t-stat? you might just have air in the system.
Old Aug 2, 2009
dbjnky's Avatar
I bled the system again and it now works like a charm. Thanks for your help. I guess it still had some air in the system.
Old Aug 2, 2009
good to hear, next time when you fill up your radiator fill it with the nose up works like a charm everytime.
Old Aug 2, 2009
rutscivic's Avatar
some of the older civics have bleeders also...crack em open and pour in the coolant till it comes out the bleeder. close bleeder, no air.
prowl
Apr 18, 2015 07:50 PM
Hondasport01
Bolt-on Engine Performance
Nov 11, 2001 12:41 PM
Hobby2K
Nov 9, 2001 04:08 PM
