ES motor mounts vibration?
Old Jul 27, 2009
madAd's Avatar
madAd is an unknown quantity at this point
I just installed the ES motor mount insert, only in the front so far because the rear wouldn't fit.(looks like everyone has had that prob and said to shave them). Anyways, my car vibrates like crazy now, espec with A/C on, the front mount was torn, will the vibration get less after I replace that? or after the inserts break in a little maybe? Or is there something that maybe wrong with my engine that would make it vibrate more?
Old Jul 27, 2009
remmick69's Avatar
remmick69 will become famous soon enough
Re: ES motor mounts vibration?
Thats normal.... mine did the samething... really bad vibration with a torn mount and ES bushings...i replaced the mount and put the ES bushings back in and got a slightly less vibration.... I have the ES bushings front mount and rear with the Ingalls stiffy... again that just made the vibration slightly less... either way ur gonna get vibration...
Old Jul 27, 2009
lordhelmet's Avatar
you'll get used to the vibration. I did on mine.
Old Jul 28, 2009
colourwolf's Avatar
colourwolf will become famous soon enough
I have the front ES with torn mount. The vibration isnt that bad when the car is moving.
But starts from a dead stop, the dash rattles, i need to give more gas than I used to.
Old Jul 28, 2009
i also have the front ES inserts on torn oem mount. first time they were noticable driving around and had some vibration but nothing crazy. when the car is moving, no vibration. at a stop, car would rumble a bit and make boom noises. now about a month later, i almost forget theyre installed. i think because i have an auto trans, and the mount is shared, it absorbs most of the vibration. right now it almost feels like stock again.
Old Jul 29, 2009
batman900's Avatar
batman900 will become famous soon enough
Installed mine 2 weeks ago, at a stop with AC on the dash vibrates so hard it looks like my cds will come out of it. Still waiting for the good ol break in.
Old Jul 29, 2009
just keep driving lol. it will def get a bit better than what it is now. when i first installed mine my mom asked why the car was shaking. the last time she rode in the car she didnt say anything. it shakes about as much as our old stock accord now.
Old Jul 30, 2009
tptuning's Avatar
tptuning is an unknown quantity at this point
Arrow Re: ES motor mounts vibration?
I had the same problem with the inserts front fits rear doesn't.
I could not get used to the shaking so I removed them en installed the Stiffy Ingalls much better and no shaking.
I had also that my screws fall out of the dash of the shaking.
Old Jul 30, 2009
do you have auto or manual? starting to look like autos are better with ES insert, and manual with stiffy.
Old Jul 30, 2009
madAd's Avatar
Mine's a manual. It seems like the vibration has gone down some after a few days of good hard driving. It does still vibrate alot at a dead stop with A/C on, more so in the afternoon when it's hot and the A/C's on cold. But like you said, nothing when driving. Bumps are definitely a lot quieter now, and more hop off the line.
Old Jul 30, 2009
04 Honda Civic's Avatar
what are the advatnages of es mount compared to OEM?
Old Jul 30, 2009
it wont break every year, prolly will outlast the car, more power since there is less engine movement, less wheel hop, better accel, less vibration while moving, etc.
Old Jul 31, 2009
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
ES motor mounts are out of the question for the daily driver. I don't even recommend window weld on the stock mounts. I had my rear mount filed with the stuff, and stock feels so much better now that I removed it. Even just the rear mount caused the car to vibrate slightly more than stock, but when I turned on the A/C, it vibrated a lot more.
I just don't understand this mod for a daily driver. What's the point, elimination of wheel hop? That's stupid because how often does that happen? And if you're going to say engine/trany movement, that's almost a non-issue. Stock feels good and I wouldn't settle for anything harder.
OEM ftw.
Old Jul 31, 2009
colourwolf's Avatar
OEM ftw.
It probably not an issue for 6th gen civic. Almost all the 7th gen have broken front motor mount problem. If it was replaced with OEM mount, it probably wont even last for a year. Thats why people choose the ES inserts rather than the OEM mount.
However, if u are looking for an comfort ride, ES definitely not an solution for you. Just replace the mounts whenever it is broken.
Old Jul 31, 2009
yeah the front mount breaks all the time. some people here went thru a mount every few months. my car feels just like stock with the front es inserts. id say in my case this is more of a daily driver mod than a stupid loud exhaust im getting tired of hearing. but if you have bad shaking then yeah maybe the es mounts are not a good idea. i had the stiffy and my car shook worse than anything and i had to take it off. others who tried it say it doesnt shake at all so idk, maybe it depends on the car and trans type.
Old Jul 31, 2009
BlueEM2's Avatar
Whachya lookin at?
I have around 75k miles on the vic and I'm still using the original motor mount. After reading the forums here I did a thorough inspection of it (what I consider thorough anyway), and could not find any breaks. I'm going to try the insert though, maybe keep the mount alive for as long as possible and see how badly it shakes.
Old Jul 25, 2010
does anyone have updates how their front mount is breaking in? i put on some more miles and can barely feel it. unless i have the a/c on, it feels stock. and even with a/c i only feel occassional vibrations in the seat and car. shifting to neutral completely stops any vibes.
Old Jul 26, 2010
02civicsi02's Avatar
Low and slow!
The vibration is normal but it shouldnt be to much. It is a great mod to have, I have them in my ep3 and I like them. It doesnt vibrate to bad unless the ac is on but still isnt to bad. The only thing with the 7th gen si you have to have this if you get a race header.
mistermenphis22
Jul 13, 2015 04:43 PM
manfredww1
Jul 12, 2015 07:31 PM
671civicLX
Jul 9, 2015 03:22 PM
