Right temperature plugs for my set up?
Old Jul 15, 2009
Running Riot's Avatar
^Warranty voider
Running Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of light
So im using stock Si plugs in my second gen JDM B16a. Stock temp is BKR6ES-11. I know the saying goes go one step colder per power adder right? Im running a 70mm tb pro1 cams, PnP and honed intake manifold and head i/h/e. Since the cams are technically a power adder that means using bkr7es-11. Thing is, the compression is higher in my engine than in the stock b16a2..... so its like having a b16a2 with higher cr pistons AND cams. So are those two power adders? Should I go to 8 or is that too cold?
Old Jul 15, 2009
Re: Right temperature plugs for my set up?
just go one step at a time but do you know if the stock plugs are even running too hot? otherwise going to a colder plug when you dont need it will cause all sorts of issues.
Old Jul 16, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
i would just stay use stock. "if its not broken dont fix it"
Old Jul 16, 2009
^Warranty voider
the plugs im using now are white with a bunch of **** on it. according to NGK its from too hot a plug and my insides are dirty. prolly seafoam it later. Im guessing the guy who had the engine before me ran crap fuel. When i popped off the plugs i looked at the piston heads and they're pretty clean so is the manifold and TB. But yeah the plugs are reading that they are too hot, i just don't know how cold to go.
Old Jul 16, 2009
go with one step colder and check them later to see what happens.
SidCivic
Nov 24, 2015 08:36 AM
159
Jul 5, 2015 09:54 PM
alex_nyc
Jun 16, 2015 01:43 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
Rushfan1
May 6, 2015 01:20 PM
