Overheating Issue
Old Jul 12, 2009
ccarlozz's Avatar
ccarlozz is an unknown quantity at this point
Overheating Issue
I have a 1998 Honda Civic EX. 166xxx miles. I just had the water pump and radiator replaced. Even after these repairs my car is still overheating. Initially the temperature will be normal (half way point on gauge) and after approximately ten minutes it creeps up. Sometimes it will go down a little, but eventually it goes back up and I have to shut the car down before it hits the red. Any ideas? The cooling system was pressure tested and there were no leaks.
Thanks.
Old Jul 12, 2009
04 Honda Civic's Avatar
Re: Overheating Issue
Do you have heat? I would say your headgasket is bad. Have someone check to see if your getting exhaust gas in your coolant.
Change your thermostat just to be on the safe side.
Old Jul 12, 2009
One_Fit_Civic's Avatar
One_Fit_Civic is an unknown quantity at this point
and get a new radiator cap your cap might not be holding the PSI
thana
Jun 15, 2020 07:05 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
Sarahwv2910
22
Jun 17, 2015 12:35 PM
zaboomafoozarg
May 30, 2015 09:21 AM
crowtoo
May 11, 2015 06:50 PM
