View Poll Results: Best platform for an all motor build
B16a/B16a2 Civic Si/SiR
5.00%
B18b/VTEC
0%
B18c3 GSR
5.00%
B18c5 Type R
15.00%
B20/VTEC
30.00%
H22/H23 Prelude
45.00%
Voters: 20. You may not vote on this poll
Wanted to see what other builders thought
Old Jul 12, 2009
Running Riot's Avatar
^Warranty voider
Running Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of lightRunning Riot is a glorious beacon of light
Question Wanted to see what other builders thought
So I ran into a guy while I was working and we got to debating as to what was the best engine to build from the ground up (restricted to all motor applications) and we based it on hp, tq, availability of parts, reliability and ease of modding. We kept it to strictly B and H series since the K is hands down the best NA platform in my humble opinion. So I wanted to see what other people out there in the civicforums world thought. I'd prefer to have people that ACTUALLY worked on them to input. Poll your answer and post why you said so.
Guidelines are:
reliability
max hp potential
max torque potential
cost to build
ease to build
Old Jul 12, 2009
Retell's Avatar
Retell is an unknown quantity at this point
Re: Wanted to see what other builders thought
No faith in the D Series?
Old Jul 12, 2009
04 Honda Civic's Avatar
I dont see k series on that list
Old Jul 12, 2009
speedfoos's Avatar
Small block Chevy 350.
/thread.
Old Jul 12, 2009
^Warranty voider
nah not for an all motor build. they max out at something like 150? I knew this guy MimikSi on another forum who built an all motor D16zC with EVERYTHING and i mean EVERYTHING stage 3 cams thinnest head gasket your imagination could possibly deal with a milled head and over sized EVERYTHING, the works, and I beleive he maxed at 140 whp with driveability issues. Thats a stock Si. As far as turboing a D series sure, but this is an all motor poll
Old Jul 12, 2009
denice25's Avatar
Member
denice25 will become famous soon enough
B16a/B16a2 Civic si/sir.....
Old Jul 12, 2009
^Warranty voider
why out of curiosity?
Old Jul 12, 2009
^Warranty voider
yeah i didnt put the K because hands down its the best platform to use for all motor builds hands down... but the price still makes it an unreasonable build for < 7th Gen simply because the engine alone is 3-4 grand + labor for the swap and for that you can build a bulletproof b20vtec so yeah. Otherwise the K series is the ****.
Old Jul 14, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
this is going in your 7th gen? if so k series is the only way. otherwise i would say an h22 has the highest potential out of all the motors to be "fast" with the least amount of money spent. h22 has a weak stock bottom end but since your building it (im assuming?) with a beefier bottom the h22 is the way to go.
good:
"no replacement for displacement"
the h22 head flows real well for stock
bad:
h22 tranny sucks (can be compensated with a b16 tranny adapter plate)
aka "H2B"
imho h2b > all except for k series
Old Jul 14, 2009
^Warranty voider
its not cuz im building it, im working on a b16 that i will eventually boost or go b20 with but i just wanted to see what other people felt out of morbid curiosity. I always stayed away from the h22 because of the carbon lined cylinder walls
Old Jul 16, 2009
forgot to add the b20 vtec as well. awesome setup for the price.
Old Jul 16, 2009
^Warranty voider
agreed hands down. When i finished my last one, it put down more torque to the wheels than my buddy's eg b18/turbo... except with a flat torque curve.
Old Jul 16, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
good:
bad:
aka "H2B"
Disagree, the H22 is too heavy for the application, it'll provide less power:weight than some of the other motors.
Old Jul 17, 2009
h22 too heavy? 35 pounds is nothing when you weigh out the advantage and disadvantage of the setups. taking out your spare will solve the problem. http://www.honda-tech.com/showthread.php?t=684550
Old Jul 17, 2009
^Warranty voider
true but if you removed the spare from a non h22 equipped vahizzle youd still be heavier by 35 lbs.
Old Jul 17, 2009
badhabits's Avatar
badhabits is an unknown quantity at this point
I miss my 87 lude with a jdm h22a swap
makes my d17 feel like im driving a kia with no muffler...
Old Jul 17, 2009
well the point was, 35 pounds shouldnt be the deciding factor when choosing a motor for your car IMHO.
Old Jul 20, 2009
sxysweed's Avatar
sxysweed is an unknown quantity at this point
Well said. Unless your building an absolutely stripped down race car, those 35 pounds will never matter. You won't notice a difference.
Your friend messed up. There's quite a few people that max the D's out at 160whp. He either did something wrong, or didn't build it right.
www.d-series.com
Old Jul 21, 2009
^Warranty voider
35 makes a big difference in forza motorsport 2 haha
in all seriousness tho
those 35lbs are also in the front, not just in the car. weight distribution plays in, depending on what kinda applications your car will be seeing...
i took out my airbags and i felt the car a bit more responsive. Could have been psychosimatic (sp?) then when i took out the spare tire, and stripped about 15-18lbs off the engine it knew it was much more responsive.
doncarbone
Jun 8, 2015 03:37 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
Jonas Powell
Apr 16, 2015 11:47 AM
ImmortalEX
Oct 31, 2001 10:00 PM
