Honda Civic 1992-1995 EG Wiper and Washer System: troubleshooting, removal and more
Old Jun 29, 2009
Spartanic's Avatar
Spartanic will become famous soon enough
Click on the link to see the complete article with images check it out here: Honda Civic 1992-1995 Wiper and Washer System. Garage411.com
A 2-speed front wiper motor with intermittent feature is used on all Honda Civic EG models. Wiper switch is part of the combination switch on the steering column. Some models are also equipped with a rear wiper/washer system.
FRONT WIPER MOTOR TEST
1. Disconnect front wiper motor 5-pin connector. Using jumper wires, connect positive battery terminal to Green/Black wire terminal and negative battery terminal to Blue wire terminal at wiper motor connector. Ensure wiper motor operates on low speed.
2. Using jumper wires, connect positive battery terminal to Green/Black wire terminal and negative battery terminal to Blue/Yellow wire terminal at wiper motor connector. Wiper motor should operate on high speed. Replace front wiper motor if it fails to operate.
REAR WIPER MOTOR TEST
1. Remove tailgate lower trim panel. Disconnect rear wiper motor 4-pin connector. Connect positive battery terminal to terminal No. 1 (Yellow/Green wire) and negative battery terminal to terminal No. 2 (Green wire). Wiper motor should operate smoothly. Replace rear wiper motor if it fails to operate.
2. Reconnect 4-pin connector. Turn rear wiper switch on. While motor is running, check voltage between terminal No. 3 (Light Green/Black wire) and terminal No. 4 (Black wire). Voltage should alternate from zero volts to more than 4 volts. If voltage is not as specified, replace rear wiper motor.
WASHER MOTOR TEST
Remove front bumper. Disconnect washer motor 2-pin connector. Connect battery voltage across washer motor terminals. Washer motor should operate smoothly. If motor runs smoothly but little or no washer fluid is pumped, check for disconnected or blocked washer fluid hose or a clogged pump outlet in motor.
WIPER/WASHER SWITCH TEST - HONDA CIVIC
Remove steering column covers. Disconnect 6-pin and 8-pin connectors from wiper/washer switch. Check continuity between specified terminals with switch in indicated positions. If continuity is not as specified, replace wiper/washer switch.
WIPER/WASHER SWITCH TEST - HONDA DEL SOL
Remove steering column cover. Disconnect 8-pin connector from wiper/washer switch. Check continuity between specified terminals with switch in indicated positions. If continuity is not as specified, replace wiper/washer switch.
TROUBLE SHOOTING
WIPERS DO NOT OPERATE IN ANY POSITION
Blown fuse No. 14 (20-amp) in dash fuse block. Faulty wiper motor assembly. Disconnected wiper linkage. Faulty wiper switch. Poor ground. Inspect Green/Black wire for open circuit. Check for loose or disconnected terminals.
WIPERS DO NOT OPERATE IN INT (INTERMITTENT) POSITION
Faulty wiper switch. Faulty wiper motor assembly. Faulty intermittent wiper relay circuit (in integrated control unit). Inspect Blue/Green, Blue/White and/or Yellow/Blue wires for open circuit. Check for loose or disconnected terminals.
WIPERS DO NOT OPERATE IN LO OR HI POSITION
WIPERS DO NOT OPERATE IN MIST POSITION
Faulty mist switch.
REAR WINDOW WIPER DOES NOT OPERATE (CIVIC)
Blown fuse No. 14 (20-amp) in dash fuse block. Faulty wiper motor assembly. Faulty wiper switch. Poor ground. Inspect Green/Black and/or Green wires for open circuit. Check for loose or disconnected terminals.
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
dooner24
Apr 14, 2015 07:51 PM
