Honda Civic 1992 - 1995 EG Manual Transmission: Removal, Installation and Overhaul
Old Jun 29, 2009
Spartanic's Avatar
Spartanic will become famous soon enough
Click on the link to see the complete article with images check it out here: Honda Civic Manual Transmission: Removal, Installation and Overhaul. Garage411.com
Transmission Removal
1. Disconnect negative and positive battery cables. Remove battery base and air cleaner and tube assembly. Disconnect starter and transaxle ground cables. Remove engine harness clamp. Disconnect Vehicle Speed Sensor (VSS) connector. Disconnect back-up light switch.
2. Remove clutch pipe bracket and clutch slave cylinder. Drain transaxle fluid. Remove starter. Remove engine and right wheelwell splash shields. Remove header pipe. Separate lower control arms from ball joints. Remove right radius rod. Using 2 large screwdrivers, pry both axle shaft inner CV joints out of transaxle. Protect axle shaft ends.
3. Using drift punch, drive out shift rod roll pin. Remove shift and extension rods. Remove inspection cover and engine stiffener brackets. Install hoist at cylinder head attachment points of engine, and lift engine slightly to unload engine mounts. Remove splash guard and front stopper bracket.
4. Place a jack under tranny, and slightly raise it to take weight off transaxle mounts. Remove front transaxle mount. Remove rear transaxle mount bracket. Remove side transaxle mount. Remove transaxle housing mount bolts. Pull transaxle away from engine, and remove tranny.
Transmission Installation
Before installation, install NEW circlips on inboard side of axle shafts. Use NEW self-locking nuts on front end of radius rod and header pipe bracket. Use NEW through bolt on firewall side transaxle mount. To install transaxle, reverse removal procedure. Tighten nuts and bolts to specification.
TRANNY REMOVAL AND INSTALLATION TORQUE SPECIFICATIONS Ft. Lbs. (N.m)
* Battery Base Mounting Bolts: 16 (22)
* Extension Rod Bolt 16 (22)
* Flywheel Housing-To-Engine Bolts: 44 (60)
* Header Pipe
o At Manifold 41 (55)
o At Flange 16 (22)
* Intake Manifold Bracket Bolts: 16 (22)
* ntermediate Shaft Support Bolt: 29 (39)
* Rear Mount-To-Transmission Bolt: 41 (55)
* Slave Cylinder-To-Housing: 16 (22)
* Starter Bolts: 33 (45)
* Stiffener Bolt: 33 (45)
* VSS Mounting Bolts: 14 (19)
* Wheel Lug Nuts: 80 (109)
S20 MANUAL TRANSMISSION OVERHAUL PROCEDURES
TRANSMISSION DISASSEMBLY
Place clutch housing on supports high enough to keep mainshaft from hitting workbench. If it is necessary to heat transmission case for component removal, DO NOT exceed 212°F (100°C).
1. Remove back-up light switch and cable bracket. Remove transmission attaching bolts, and disconnect breather tube. Remove 32-mm sealing plug (plug has square hole). Expand snap ring on countershaft ball bearing. Separate transmission housing from clutch housing.
2. Measure clearance between reverse shift fork and shift piece pin.Clearance should be .002-.014" (.05-.35 mm). Service limit is .020" (.50 mm). If clearance exceeds limit, measure width of "L" groove in reverse shift fork. Width should be .278-.285" (7.05-7.25 mm). Replace reverse shift fork if width exceeds specification.
3. Measure clearance between reverse idler gear and reverse shift fork. Clearance should be .020-.043" (.50-1.10 mm). Service limit is .071" (1.80 mm). If clearance exceeds service limit, measure width of reverse shift fork pawl opening. Width should be .500-.512" (12.70-13.00 mm). If width exceeds limit, replace shift fork.
4. Remove reverse shift fork. Remove reverse idler gear shaft and gear. Remove interlock guide bolt from under clutch housing. Remove shift arm "B" bolt. Tape mainshaft splines for protection. Remove mainshaft and countershaft with shift forks as an assembly from clutch housing. Remove differential assembly.
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
twtron
Apr 17, 2015 12:09 AM
aZnVoYCe
Dec 7, 2001 12:41 AM
