Control Arm Removal Gone Wrong, Safe to Drive?
Old Jun 14, 2009
bobbob2x's Avatar
bobbob2x is an unknown quantity at this point
Control Arm Removal Gone Wrong Safe to Drive?
Long story short I tried to take of my lower control arm and failed at in miserably due to a lack of the right tools. Using a pickle for I ripped my boot to pieces and along with that I striped the inner part of the screw that holds the sway bar on so, which isn’t completely tightened now. When I drive the car I now hear a clunk when I drive over any bumps large or small. Also when I turn I hear a knocking noise. Form some of the research I did I herd this is due to the sway bar being lose. Is this right? Also what is causing the noise I hear over bumps and most importantly is my car safe to drive to work for the next week while I order tools and replacement parts? I would very much appreciated any help
Old Jun 14, 2009
johnnyboy5000's Avatar
johnnyboy5000 is an unknown quantity at this point
Re: Control Arm Removal Gone Wrong, Safe to Drive?
Long story short I tried to take of my lower control arm and failed at in miserably due to a lack of the right tools. Using a pickle for I ripped my boot to pieces and along with that I striped the inner part of the screw that holds the sway bar on so, which isn’t completely tightened now. When I drive the car I now hear a clunk when I drive over any bumps large or small. Also when I turn I hear a knocking noise. Form some of the research I did I heard this is due to the sway bar being lose. Is this right? Also what is causing the noise I hear over bumps and most importantly is my car safe to drive to work for the next week while I order tools and replacement parts? I would very much appreciated any help
I brought my 02 civic to Pep Boys three years ago for a clunk sound in the turns. They said I needed new control arm bushing. I said OK, they installed them, but a couple days later the clunk came back. Pep Boys stripped the welded bolt on the sub frame. I was on a road trip when I discovered the bolt kind of hanging out of the control arm. A local mechanic told me if the bolt came out when I was driving, the car would wreck. Had a Honda dealer fix it. They knocked out the old welded bolt and used similar loose bolt to fix it. It's been three years and the fix is good. I drove about 500 miles doing about 80mph in the bad condition.
Old Jun 14, 2009
bobbob2x's Avatar
what about the clunk over bumps and thanks for the replay
Old Jun 15, 2009
madAd's Avatar
madAd is an unknown quantity at this point
Should be safe for a little while, as long as you tightened everything back up, the sway bar being loose won't cause anything to wreck. I replaced my sway bar links with Moog links, they actually have a spot on the base of the stud to put a real wrench on while you loosen the nut. Ended up having to cut the old ones off with a fiber wheel and a sawzall. If you're buying a new control arm from Honda it comes with the balljoint and boot already installed for $113 from Majestic Honda, just did this myself 'cause mine got bent in an accident. That's with bushings included too. Otherwise, I think a balljoint by itself is about $50.
Old Jun 15, 2009
madAd's Avatar
I forgot to emphasize this, make absolutely sure that the ball-joint is tightened all the way and the circlip is through the castle-nut. With the front wheels off of the ground, frame on jack-stands, use a large pry-bar under the tire and pry upward between ground and tire, watch the balljoint and make sure it doesn't move up and down. If ball-joint is O.K. it should be safe, I've seen a couple of cars in the last few weeks that the ball-joint broke on, not pretty.
Old Jun 15, 2009
bobbob2x's Avatar
The ball joint is fully in I believe and the nut is on tight and the pin is full in. Although the sway bar is loose as **** and I hope it’s the cause of all the noise I keep hearing as my car stops, starts and slows down, and when I turn. I can’t get the bolt off or on and I’m going to have to cut it as soon as I can get a replacement. Its so loose I think there’s 1/8 of were the bolt needs to be tightened. I think the piece might snap soon. Will those cause major issue when it does? I have the replacement bushings, and a new ball joint ordered.
Others things I forgot to do possibly tighten the lugs on the other sides when I didn't do work on it. Today on my why home my wheel came off. Dam I hate my life
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
GolNat
Sep 10, 2015 08:25 PM
bryden13
May 18, 2015 12:22 PM
Pudnite
May 9, 2015 07:51 PM
bsmiley
Apr 27, 2015 01:27 PM
