8th Gen 2006 - 2011.
Syn Oil/Replacement Oil Pan Plugs - A twofer!
Old Jun 11, 2009
zeusx99's Avatar
zeusx99 is an unknown quantity at this point
I went to Autozone today to pick up the necessary parts for an oil change, except that they didn't have the exact plug for an '08 LX in their system. They prompted me to go pick one up at the dealership, which had since closed about an hour previous. By the time I got home, I realized that they had one for an '06, and that the plug size might be the same seeing as there are many similarities for parts in the 8th gen line. Am I wrong in thinking so?
Also, I picked up a Mobil1 syn oil since a fellow civic enthusiast recommended it for DIY oil changes. However, I've come across a number of threads warning against syn oils in the D18 engines. After extensive reading on the subject of oils, syn v dino and others, I'm still stumped. So I guess I would simply be wondering if I should use the syn oil in my car that only has 16k miles on it so far.
Search function didn't really give me anything to go on for this issue.
Old Jun 12, 2009
04 Honda Civic's Avatar
Re: Syn Oil/Replacement Oil Pan Plugs - A twofer!
I dont see how using synthetic oil in your motor differs from any other motor? The 06 plug would have probably fit. Why are u changing the plug? Normally you just change the crush washer with it.
Old Jun 12, 2009
zeusx99's Avatar
That's what I thought, but apparently I shouldn't trust what some kid at autozone is telling me. Thanks.
Old Jun 12, 2009
Mr. Showtime's Avatar
Mr. Showtime is an unknown quantity at this point
Before consulting any employees of Autozone, be sure to ask them to identify their *** as well as their elbow. Most will be unable to differentiate.
Old Jun 12, 2009
check sparkplugs.com for the proper part number. im sure all 06-09 are the same (SI is prolly different). and stick with a good conventional oil like valvoline.
Vaguexo
Jun 13, 2015 04:11 AM
Mercilus
Jun 7, 2015 10:00 PM
jmdcivic
May 20, 2015 09:52 PM
leon1
Apr 28, 2015 07:32 PM
Grey
16
Jan 27, 2002 11:34 PM
