Heat issues in 2001 Civic
I'm having issues with my heat, and need some new ideas please.
Recently I noticed that my civic is blowing cold, possible lukewarm air when the heat dial is cranked to full hot. If the engine has been running hard, it will be on the higher end of lukewarm...otherwise, just cold.
I cannot see it being the thermostat, as it was just replaced a few months ago when my water pump was replaced. And, the temp gauge in the instrument panel stays at normal running temp - no fluctuations.
Coolant levels are topped up, and don't fall.
I opened up the rad cap, ran the engine, and got rid of a few air pockets in the system...didn't help.
All hoses get very hot when running - BUT - one that returns from the heater core didn't really warm up at first. I had to work it a little before the temp/pressure seemed to come up - problem??
Anyone have any ideas? Thanks.
- oh, and I'm not really mechanically inclined...so talk slowly and simply
Re: Heat issues in 2001 Civic
otherwise you could have a clogged heater core.
good idea..make sure you do what gearbox said. Open the rad cap park on a hill or jack up the front of the car nose up and run the car for some time with your heat on full blast. Make sure that your car is topped off on coolant before you do this. After you do this you may have to add some coolant so dont forget to check your level.
Thanks for the responses.
Yes, I did have the dial to FULL HOT and ran the fan at FULL with the cap off. I jacked up the passenger side. Maybe I'll try doing it again right in front and see if that helps.
...hope it's not the heater core. Is that a costly fix?
You say the heater hoses get hot (to the core). Are you sure the valve is opening completely? It's between the engine and heater core, next to the firewall....
So, how would I know if it is opening completely?
No, I'm not sure...my mechanic did mention it and wiggled it, but wasn't sure what it's movement range was supposed to be...then it detached and he swore for about 10 minutes trying to put it back on...I assume that is what you are talking about...
BTW, I highly doubt the valve would fail. If anything, the motor/switch would no longer be moving the valve as it's supposed to. Not sure how to fix that, but I'd imagine you'd have to take the dash apart...
mattdoc
Mar 14, 2017 12:10 PM
CapYoda
Nov 11, 2001 05:17 PM
Lightman
Nov 10, 2001 06:44 PM
