'97 DX Stalls, PLS help
Old May 15, 2009
sfrankel's Avatar
sfrankel is an unknown quantity at this point
Two weeks ago, I went to start my car, and it threw me the check engine light. I reset it, and then it did it again. At the same time, the car started to stall on me occasionally when I came to a stop sign. I checked the error code p0135 and ordered a new o2 sensor. When I went to replace the sensor, I saw the exhaust manifold/cat converter was cracked right where the 1st o2 sensor threads in. I had a guy in a shop weld it, and then I went and replaced the sensor. All was good, until I was coming to a stop at the end of an off ramp to the highway, and the car stalled again. Arrg!! I thought I had fixed the problem. Any body have a similar experience or know what might be the problem? Thanks for your help.
Old May 15, 2009
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
Re: '97 DX Stalls, PLS help
mine does the same thing, it started when I swapped ELD's with my brother (his was bad)
Old May 15, 2009
flyboy1304's Avatar
flyboy1304 is an unknown quantity at this point
Eld???
