1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
1994 Sunroof pulling unevenly
Old May 10, 2009
silentz's Avatar
silentz is an unknown quantity at this point
This happened a few weeks ago. I noticed the sunroof motor is struggling every time i open or close the sunroof. Just today, i checked it and saw that the driver side is pulling faster than the passenger side when closing/opening and it made a mechanical struggling trying to pull the passenger side in.
OK, any solution for this or I'm screw and need a new sunroof motor?
thanks
1994 Civic EX Coupe
Old May 11, 2009
Re: 1994 Sunroof pulling unevenly
try and spray the tracks with white lithium grease.
Old May 15, 2009
silentz's Avatar
thanks for the reply. i'll buy that and put it on this weekend.
Also, I have a leakage from the front windshield on the driver side. What could cause this? Like droplets of water dropping down onto the seat when it rains for a while.
Old May 15, 2009
a bad window seal. you could try and repair it without removing the window, just check around and see where the water is coming from on the outside, then buy some black rubber sealer and squirt some inside the area behind the molding. it will dry and form a waterproof seal.
Old May 18, 2009
silentz's Avatar
I emptied half the lithium grease tube on both side of the sunroof. I spent about 30mins pulling and closing the roof so the grease apply evenly and it still pulled uneven and mechanical struggling. So it's the motor right? is there anyway to adjust the motor?
Also bought the black rubber sealer and applied it plentifully. Waiting for a hard rainy day to see the result.
Old May 18, 2009
hmm i dont know alot about sunroof but there should be a way to adjust it. the motor usually either works or doesnt work. so maybe something like the slider got loose or out of track. see if you can find anything that doesnt look right. you may need to take the roofliner off tho to see the sides.
SimpleUser
Apr 24, 2021 02:54 AM
mrwhos
Aug 11, 2015 02:03 AM
tattedlariat
Aug 4, 2015 06:35 PM
JDMnoob
Aug 2, 2015 02:38 PM
viperGTS
Jul 27, 2015 08:40 PM
