Will Progress Front RSX Sway Bar Fit the Civic EX? (will it clear the cat?)
I found some threads where people used the Progress 61.0102 RSX front sway bar on the civic.
Anyone know if it'll also work with the Civic EX, which has the cat underneith the car?
Re: Will Progress Front RSX Sway Bar Fit the Civic EX? (will it clear the cat?)
Do you really know what a bigger front sway bar will do? Know the difference between changing the front and rear sways?
I don't know if it will fit or not, but I just checked and progress does make a front sway bar for the 7thgen Civics, so you may want to check that out. Unless you're looking at buying a used RSX one specifically.
