2003 EX sputtering in idle with Check Engine light
Old Apr 24, 2009
pcheruka's Avatar
pcheruka is an unknown quantity at this point
Question 2003 EX sputtering in idle with Check Engine light
Codes
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
67000 miles; Any suggestions where to start?
Old Apr 24, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
Re: 2003 EX sputtering in idle with Check Engine light
I would start by checking if the spark plugs work
Old Apr 25, 2009
yeah either plugs or clogged injectors or low fuel pressure (bad fuel pump) or bad ignition coils (very rare). if its not those, you have more serious problems like a blown headgasket.
Old Apr 27, 2009
Tomj333_EM2's Avatar
Tomj333_EM2 is an unknown quantity at this point
All for cylinders.... could be obviously plugs.
But im sure it wouldnt cause all four at once, I'd say maybe fuel badly clogged air box.. or more seriously head gasket.
Does your oil have coolant in it?
Old Apr 27, 2009
pcheruka's Avatar
Nope, Oil is clean.. No start up problem at all. Idle goes around 1200 and settles to around 750 and then sputtering;
One mechanic said it's the computer control, a change would require reprogramming keys also; make any sense?
Old Apr 28, 2009
Anathema's Avatar
The internet says Im a loser
Anathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of lightAnathema is a glorious beacon of light
I had this same problem.. Same CEL codes and everything..
In my case, it was the TB and IAC valve.. Spoke with Gearbox about it..
Originally Posted by gearbox
it is the piece bolted to the TB with the two coolant lines feeding into it. just take the radiator cap off to depressurize the system, then remove the coolant lines. its easier to remove the whole tb and then take off the iac valve to clean it. just spray carb cleaner to get out the carbon buildup. the only problem is sometimes the screws are really hard to remove.
iac by itself
more pics
Old May 2, 2009
pcheruka's Avatar
well, in order to completely eliminate any ignition problems, i decided to change the spark plugs and start with the cheapest option. I had checked these out visually a couple of days into the problem. Nothing was noticed then, plus, I had no start up or pick up problem, except for the sputtering in idle.
When I dropped the third plug on to the floor, I noticed the spark tip ceramic inlay on that plug split. I assume this had a hairline crack, which I failed to notice earlier, and it split upon shock when it hit the floor.
That was it, with new platinum tip plugs it's running smooth...................;-)) Good day to everyone... Thanks for your input
Old May 2, 2009
good to hear
Old May 3, 2009
Anathema's Avatar
Congrats man, glad to hear you got the problem solved without big $$..
Old May 3, 2009
whitealexander's Avatar
whitealexander is an unknown quantity at this point
glad to hear you fixed it..
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
deus-ex
Apr 13, 2015 12:29 PM
