SOLD: new energy susp. front sway bar bushing set
Old Apr 24, 2009
i have a brand new set of energy suspension poly bushings for the front sway bar. i got the wrong size for my car. the size of these bushings is 1 inch or 25.4mm. Please read carefully: these will only fit 2001 civic coupes and sedans (all models), and 2002 coupes (all models). will NOT fit 2002 sedans or any 03-05 civic.
asking $20 shipped
Old Apr 24, 2009
FALKEN's Avatar
Civicforums Junkie
Re: FS: new energy susp. front sway bar bushing set
I have these 25.4mm bushings on my 2001 sedan...
Theyre definitely worth the $20
Old Apr 24, 2009
MidnightCivic's Avatar
How hard are they to install and what do they do?
Old Apr 24, 2009
keeps the swaybar from moving as much as with the oem rubber bushings, which allows the suspension to perform better. also they last the life of the car instead of tearing and cracking. i already ordered some of the 23mm rsx bushings for my 02 sedan so i need to sell these. install is very easy. jack up the front of the car (from the middle) until both the front wheels are off the ground to unload the suspension. then just unbolt the two sway bar bushing brakcets, slide off the oem and slide on the es and then rebolt the brackets. its two bolts per side and you can use a cheater pipe if the bolts are stuck. lower the car and drive it around. if you do not jack the car up, you will not be able to get the bracket bolts to line back up.
Old Apr 25, 2009
bump anyone?
Old Apr 28, 2009
bump nobody?>
Old Apr 28, 2009
youngjosh12's Avatar
youngjosh12 is an unknown quantity at this point
Bump
^^I thought the 02 Sedans had a 1" front bar, same as the coupe? They didnt specify for mine, good thing they fit!! ^^
Bump either way!!!
Old Apr 28, 2009
02 sedan (like me) is only 22.2mm bar (0.874 inch) so you need the rsx 23mm bushings. these 25.4mm are too big. they will fit but you will have alot of empty space around the bar and bushing so basically the sway bar will not work correctly.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
