okay im about to change my spark plugs
Old Apr 16, 2009
ross3093's Avatar
ross3093 is an unknown quantity at this point
I have a 03 civic ex sedan
plugs are bosch platinum 4030
couple Q's
1 do i need to change vtec fluid if so where what how
2 whats the best time to change plugs before or after oil change?
3 if I am switching to synthetic oil on my next oil change does that affect anything?
4 what should I be extra careful of if im doing this for the 1st time (besides letting something fall in the engine, and not using anti seize lube)
Old Apr 16, 2009
Re: okay im about to change my spark plugs
1. throw away bosch plugs, they dont belong in a honda
2. buy some NGK v-power plugs and install
3. tighten them no more than 20 ft/lbs
4. do NOT use anti seize, do not lose the coil pack nuts
Old Apr 16, 2009
ross3093's Avatar
how bad are bosh? for 10$ for 4 it seems like a good deal
what about
AUTOLITE Platinum Spark Plugs
Old Apr 16, 2009
Originally Posted by gearbox
2. buy some NGK v-power plugs and install ($2 each)
Old Apr 16, 2009
thewal's Avatar
thewal will become famous soon enough
howcome you said not to use antiseize?
Old Apr 16, 2009
sethro's Avatar
sethro is an unknown quantity at this point
X2 With what Gear said NGK is standard for Honda's. Everything else is just a gimmick.
There is no such thing as VTEC fluid.
Old Apr 16, 2009
lowlife9's Avatar
what denso iridium are the best for honda.bosch will make your car run like ****.it doesn't matter which you do first oil or plugs.and it will have no consequences to switching to synthetic unless your car is burning oil now.and the v-tech fluid has to be changed by a honda dealer call and ask for a qote
Old Apr 16, 2009
with anti-seize you will not be able to torque the plugs properly. and spark plugs never get stuck anyway so its not needed. with 20 ft/lbs of tightening force, they should never get stuck. also do not change the plugs when the engine is hot.
Old Apr 16, 2009
thewal's Avatar
thanks, good to know.
Old Apr 17, 2009
Dticalman81's Avatar
Dticalman81 is an unknown quantity at this point
Talking Re: okay im about to change my spark plugs
Yes, I agree. Denso Iridium ik20's Are the best for our cars. They run about $10-15 each depending where u get them.
Old Apr 17, 2009
denso iridium ftw if you can afford it. otherwise copper ngk is good too. denso has smaller center electrode that requires less power to make the same spark. so electrical system does not work as hard.
Old Apr 17, 2009
True that.
Old Apr 17, 2009
04 Honda Civic's Avatar
Vtec fluid hah..I never change mine vrooom
Old Apr 17, 2009
jagass's Avatar
jagass is an unknown quantity at this point
I thought that Bosche are great...
Old Apr 17, 2009
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
you dont need denso iridiums. Just get platinum Densos or NGK that were in the car from honda, not like your boosting.
Part No. 7100 from NGK
Old Apr 17, 2009
Originally Posted by cwo715
you dont need denso iridiums. Just get platinum Densos or NGK that were in the car from honda.
No, No. It's not true. I know what you're saying, but I added just one ik20 plug and from then on, i noticed the difference. Please listen to your peers and put in the right thing: denso iridium ik20's. $10-15 but it's so worth it! lol..
Old Apr 18, 2009
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
lol I dont come back for awhile and the first thread I see is this.....vtec fluid? Cerealy?
Old Apr 20, 2009
ross3093's Avatar
okay got some v powers! hehe what about wiring harness should this be replaced? there is a good deal at autozone 20$ rebate
Old Apr 20, 2009
jamis33's Avatar
You Stay Classy, San Diego
i like the ngk iridium. They are a bit cheaper than denso and i like them better. Just my $.02
Old Apr 20, 2009
wire harness? you mean the spark plug wires (assuming you have 2000 civic or below)? yeah its a good idea to replace em if they look old. the carbon inside breaks down over time.
Old Apr 21, 2009
Get the ik20's. Or for older models it's the ik16. Be wise. I've compared to v-powers already, they suk.
Old Apr 21, 2009
2005EM2's Avatar
My Honda Loves Me ^_^
Wink Re: okay im about to change my spark plugs
Wow.. I read the OP's post on VTEC fluid. I giggled.
Old Apr 21, 2009
Shouldnt always go according to how they look, lol my dad does that.. but really resistance is key
Old Apr 21, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
make sure you set the gap correctly. im guessing you dont know anything about gapping spark plugs, since someone talked to into believing you had vtec fluid. :/ i believe the gap should be 44
Old Apr 21, 2009
also, do one at a time so u dont mix the coil packs..its probably not a big deal, but better be safe then sorry
Old Apr 21, 2009
boonecivic's Avatar
boonecivic will become famous soon enoughboonecivic will become famous soon enough
Im curious, how often should you replace the plugs. Not the spark plugs themselves, but the plugs that go over them.
Old Apr 21, 2009
i mix mine all the time no problems. keeps the ecu on its toes lol
Old Apr 21, 2009
cwo715's Avatar
Falken Master
Again, you dont need them, and you wont feel a difference, the thing with iridium is that they can hold a hotter spark. Iridium is not a strong metal like platinum, but platinum has a lower melting point PER-SAY than iridium, which is why most people who run turbo chargers run iridium. There really isnt a smoother difference, nor will it make your car any faster, the only thing it will do is burn a whole in your wallet if you have to change them every 30k to 50k miles. Also i recommend using a small amount of anti-seize, just a dab will do.
Old Apr 21, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
How much are the NGK and where in Canada can I buy them?
Old Apr 21, 2009
boonecivic's Avatar
What commercial auto parts store are in Canada?
