HELP! Engine Codes P0335, P0336
Re: HELP! Engine Codes P0335, P0336
very costly, like replacing the timing belt. in fact you may as well have the belt replaced cause the labor will be the same.
you might be able to just replace the crank sensor of course you do have to pull off the crank pulley and lower timing cover to get to it and gearbox is right once you are in that far you might as well change out the timing belt
tylerginevan
Apr 27, 2015 12:29 PM
