96 VTI ECU seems has Problem
Old Apr 11, 2009
Kemo0o's Avatar
Kemo0o is an unknown quantity at this point
Hello Every Body
i have civic 96 VTI AT , as i know that VTEC works at 4.5K or 5.4K rpm as i can hear sound for it like nice whistle now VTEC works @ 6.2K then the Gear shift to higher gear @6.5K
i want to know where is the problem !!
Old Apr 11, 2009
Kemo0o's Avatar
Re: 96 VTI ECU seems has Problem
where r u ??
Old Apr 11, 2009
what is wrong exactly, its not shifting gear properly? is the check engine light on?
Old Apr 11, 2009
Kemo0o's Avatar
No CEL is off
Gear working perfect but Vtec works lately @ 6.2K but it must work as i know between 4.5K or 5.4K rpm ?? The car is 100% Stock
Old Apr 11, 2009
well im not sure when the vtec works in that car, but above 6k is too high. normally the check engine light would come on. i know on the newer cars the vtec only works if you are at full throttle and the car is warmed up with enough oil. maybe check the oil level?
Old Apr 12, 2009
Kemo0o's Avatar
Oil is new ... No warnings in the car ... Gearbox oil also new
may be there is ECU Problem ???
I bought the car soon ... if the previous owner plugged out the (-) Battery cable may cause the problem ?? i plugged out The (+) Cable as there was problem with airbags then i fixed it ...
- No errors on Scan Tool ??
** Why VTEC Works lately !!!!!!!!!!!!!!!!!
Old Apr 12, 2009
Kemo0o's Avatar
sorry For Duplicatining
Old Apr 12, 2009
magikshark's Avatar
magikshark is an unknown quantity at this point
dude i think your vtec is just set to 6k.do u have a vtec controller?
Old Apr 12, 2009
Kemo0o's Avatar
What do u mean ?? also other car with the same model - VTEC - works @ approximately 4.5 K
Old Apr 12, 2009
Kemo0o's Avatar
what's up ?!!
juror
Jun 9, 2015 02:15 PM
beveragemp
May 25, 2015 07:11 PM
eorlando1
May 17, 2015 11:16 AM
McD
Apr 22, 2015 05:28 PM
dooner24
Apr 14, 2015 07:51 PM
