Need help with an heater issue on Honda Civic 2003
Hello,
The issue is a bit weird. In short, I cannot control the temperature of the heater at will.
If the car has been run for a while at a certain temperature (fan on, air from outside), I cannot change the temperature anymore until I shut the car off and let the engine cool off.
The engine temperature is normal, ad coolant in the radiator is filled propely.
Thanks for all your feedback.
Re: Need help with an heater issue on Honda Civic 2003
im not sure, aside from buying a new control dial piece on ebay and swapping it in. it may also be a problem with the mechanical parts, i know when you turn the dial hot and cold, stuff moves in the dash. maybe its sticking in one position even tho the switch works.
Blaster30
Apr 22, 2015 12:21 PM
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
dooner24
Apr 14, 2015 07:51 PM
