'89 Alternatore Removal Help Needed
Old Apr 6, 2009
vtville's Avatar
vtville is an unknown quantity at this point
Hi - I'm hoping someone might be able to give me a couple tips.
I'm removing the alternator from my 89. Got nuts/bolts off, got wires off on back of the alternator. But I can not for the life of me figure out how to get the pin out of the bottom of the alternator. I'm at a point where the alternator swings loosely, and I can see the pin/bolt moving as I swing the alternator. But, how do you push that bolt/pin through to get it out.
I took the front driver side wheel off, and the shroud for the crankcase off to get at the alt since it's in such a difficult spot. Just can't get that pin out.
Any ideas? Am I missing something easy?
thanks much
Old Apr 13, 2009
vtville's Avatar
Re: '89 Alternatore Removal Help Needed
bump for help...thanks
Old Apr 13, 2009
try hitting it with a rubber mallet? it should slide right off the pin. maybe you are pushing the alt the wrong way.
Old Apr 13, 2009
skipbarber's Avatar
if the long bolt is out you just have to wiggle it back and fourth, maybe pry on it gently to work it out.
CarStuff
Dec 6, 2020 12:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Myredjonda
Apr 14, 2015 07:00 PM
ilgnay
Apr 26, 2010 11:53 PM
Unleaded
Jun 26, 2007 09:25 PM
