1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
89 Civic Alternator help needed!
Old Apr 6, 2009
vtville's Avatar
vtville is an unknown quantity at this point
Hi - I'm hoping someone might be able to give me a couple tips.
I'm removing the alternator from my 89. Got nuts/bolts off, got wires off on back of the alternator. But I can not for the life of me figure out how to get the pin out of the bottom of the alternator. I'm at a point where the alternator swings loosely, and I can see the pin/bolt moving as I swing the alternator. But, how do you push that bolt/pin through to get it out.
I took the front driver side wheel off, and the shroud for the crankcase off to get at the alt since it's in such a difficult spot. Just can't get that pin out.
Any ideas? Am I missing something easy?
thanks much
Old Jun 20, 2011
CVCFRMREG89's Avatar
CVCFRMREG89 is an unknown quantity at this point
Re: 89 Civic Alternator help needed!
Find a slightly smaller diameter shaft (a five inch long bolt should do) compared to the diameter of the bolt (larger shaft) used on the alternator. Punch out the alternator bolt using the smaller diameter five inch long bolt (hammer required). The smaller diameter bolt should be easy to take out by pulling it with a vice grip plier.
Not sure, but perhaps replace the alternator brush(s) and your alternator should work again. The brushes are attached to one end of the rotor shaft (where the wire connectors are on that end). You can identify it by its orange colored rubber cover. Three nuts to un-screw and un-capped the silver painted metal cover of the alternator of that end.
smmahan
Apr 15, 2015 08:17 PM
Myredjonda
Apr 14, 2015 07:00 PM
Hrddrvs
Apr 11, 2015 11:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Slickwillie
Nov 5, 2001 03:48 PM
