Wiring Aftermarket radio Dual XDM6400BT for Honda civic 04 lx
So i just bought this radio and i took the old radio out and everything and when i was wiring up the new harness i realized that some of the colours were different i don't know how to match em up properly I did read the manual for radio but it still does not make much sense and would appreciate any help on wiring it up.
Re: Wiring Aftermarket radio Dual XDM6400BT for Honda civic 04 lx
I dunno if coupe and sedan is the same but for the sedan here is how it is.
Yel/Red - Hot in Acc or On (+)
Pink - Rear Right (+)
Blu/Wht - Rear Left (+)
Grn/Yel - Front Left (+)
Grn/Blk - Front Right (+)
Red/Blk - Illumination Lights (+)
Wht/Red - Constant Battery Power (+)
Blu/Yel - Rear Right (-)
Blu/Blk - Rear Left (-)
Gry/Red - Front Left (-)
Lt Grn - Front Right (-)
Red - Illumination Lights (-)
Black - Ground (-)
Black - Ground (-)
ok i had made a big mistake, i cut the harness off yes i am a noob, i went and talked to some dude at canadian tire and he said i should have not cut the original harness now its goin to be more work for fix it
Yea true, normally you dont cut the OEM harness, you can still wire it up without it. If you want you can buy a Metra 71-1721 Male lead harness, wire that up, then buy a Metra 70-1721 Wiring harness for the radio. Its not the end of the world.
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
