95 dx manual running rough after 2nd start
I have a 95 dx manual that is running great, except that when I go to restart it after I've stopped for food/gas/anything that only takes a couple of minutes.
The problem I've noticed is that it starts and runs really rough and seems like it wants to die. I can power through it and once I get to about 20-25 mph it starts to run normally again. I just had the thermostat replaced because it was overheating. While that was being done my mechanic decided to clean the "throttle body" (that little valve that regulates the air flow).
I don't think the the rough starts were caused by him doing that. But wtf do I know.
So cliffs: no problem starting cold, once warmed up and I turn the car off the engine runs VERY rough.
Re: 95 dx manual running rough after 2nd start
almost sounds like a vacuum leak or the guy forgot to plug something in around the throttle body area. look around the engine see if everything looks connected.
Ok, so I took it to my mechanic and he looked at the IACV and FITV. The problem did not go away. He is "thinking" that it could be a small leak in the head gasket. Which, with the cost of the radiator and labor will bring the total for this trip up to around $1000 and possibly above.
I am thinking its not worth it. Any thoughts.
are there any stored engine codes? its possible that the headgasket has a small leak allowing coolant into the cylinders which is then being burned and causing misfires. could be something else tho too.
Well as it turns out the head is definitely leaking. So I pulled the head off and am taking it to a mechanic to find out how much the head is warped. I have all of the new gaskets already, high temp thread locker, and some kind of silicone lube. I am going to be buying new head bolts and gasket glue.
Does anyone know what the sequence is for tightening down the head bolts, my service manual doesn't say.
CarStuff
Dec 6, 2020 12:52 PM
mistermenphis22
Apr 3, 2016 08:06 AM
civic_gt
Apr 19, 2015 08:15 AM
black2k1vtec
Dec 6, 2001 09:49 PM
