Timing belt change
Old Mar 15, 2009
baymee's Avatar
baymee is an unknown quantity at this point
Timing belt change
Are the Civic and Hyundai 4 cylinder engines similar as far as changing the timing belt? And would I use the same special tool for removing the crank bolt? 2001 models
Old Mar 15, 2009
sl33pyriceboi's Avatar
Re: Timing belt change
SEARCH.......there is a DIY on this forum on how to take ur timing belt off. observe that.
Old Mar 15, 2009
should be the same idea, the special tool you need but im not sure if theyre the same size or not.
Old Mar 15, 2009
04 Honda Civic's Avatar
its similar
mattdoc
Mar 14, 2017 12:10 PM
Supramk3
May 11, 2015 07:55 PM
slynger
18
May 8, 2015 06:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
CivicVoz
Apr 16, 2015 08:07 PM
