Please Help rear speakers wont fit
Old Feb 28, 2009
Xplod590's Avatar
Xplod590 is an unknown quantity at this point
i am replacing the rear speakers in my 04 civic coupe and the speakers i bought when i place them in the magnets hits the bars underneath. its the bars for the trunk to stay open. and when i try to open my trunk them bars hit the magnets. any help would be great. thanks
Old Feb 28, 2009
lowlife9's Avatar
Re: Please Help rear speakers wont fit
aaahhhhh try taking the plastic panel off and load the speaker from the top . maybe evan cut some wood spacers or return the speakers for shallower ones
Old Feb 28, 2009
kcari's Avatar
remove the bars. or get a spacer, but with a spacer, one corner of your speaker might hit the glass.
Old Feb 28, 2009
skipbarber's Avatar
fold your seats down and check to see if they clear with the trunk closed. My alpine type S's have rubbed for years and i havent had any problems, since they clear when the trunk is closed.
Old Feb 28, 2009
Xplod590's Avatar
i have took all my panels out of the car (installed dynamat threw out). when i loaded them from the top they stuck up about 1/4 inch wit the trunk open. ill try to put them in with the trunk closed and see if i can still open my trunk. Kcari if i remove the bars the trunk wont stay up when open. that is the tensenor for the trunk lid. I may do this since i dont use my trunk very often anyway after i finish my system i wont have much trunk space anyway.
Old Mar 1, 2009
kcari's Avatar
the probwith removing the bar is that u gotta lift the trunk up urself
Old Mar 1, 2009
manahoonie's Avatar
you need spacers... they lift the speaker some so the magnet clears. You will probably have to make them yourself out of wood or something, as I do not know if Metra makes one for the rears...they do however make one for the front as the hole is kinda weird...
Old Mar 2, 2009
Xplod590's Avatar
thanks to all for the help. I'll make me some spacers today.
Old Mar 2, 2009
you may want to switch from the torsion bars to the trunk shocks/lift supports that are used when a spoiler is installed.
Old Mar 14, 2009
jamis33's Avatar
You Stay Classy, San Diego
i agree with gearbox. If you just make trunk shocks it will solve the problem. Also i was wondering wont you lose some sound quality if you put spacers in because the sound will go out the sides of the speaker. Im picturing spacers as just going at a few points and their being a gap all around the rest of the speaker. Wouldnt that change the sound of them and make them sound worse?
Old Mar 14, 2009
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
I second that. Best route.
Jeffdp
Aug 5, 2015 11:38 AM
Causemo
Jul 4, 2015 07:11 AM
Jeffdp
Jun 18, 2015 06:18 PM
Galvezj11
Jun 17, 2015 04:13 PM
