timing belt replacement by age
Old Feb 22, 2009
Fabio Drummond's Avatar
Fabio Drummond is an unknown quantity at this point
Question timing belt replacement by age
I have a 2002 Civic Sedan LX, which has only a little more than 10k miles (about 16k km), although it will be 7 years old (of course) in next june. Such a low mileage is result of a health problem I had, but the car has been used used, very sparinglly, by my sons, and is in perfect shape.
The question is : the owners manual says 110k miles (176k km) as the interval between replacements of the timing belt, or 7 years of use. So, I ask to the friends, is it really necessary in this special case, or may I delay the replacement? Many thanks, and excuses for the bad english.
Old Feb 22, 2009
speedfoos's Avatar
Re: timing belt replacement by age
Where are you located and what is the climate? If it is hot and dry, then I would replace it soon as the rubber can become dry, brittle and risk breaking. If you are in a temperate region - like the middle western part of the USA, then I would leave it alone.
Old Feb 23, 2009
Speedfoos, I live in the eastern part of Brazil, where the climate isn't very dry, but somewhat hot. So, I'll take your advice and replace the belt as soon as possible.
Thank you very much.
Old Mar 1, 2009
d0ughbOy81's Avatar
d0ughbOy81 is an unknown quantity at this point
honda says 120000 mile time for a timing belt but while ur in there u should do the water pump and bent tensioner
but i would agree with speedfoos
Old Mar 1, 2009
OK, dOughbOy, I'll not forget to do this. Many thanks.
Old Mar 2, 2009
greeny_beany's Avatar
greeny_beany is an unknown quantity at this point
i got mine replaced yesterday,have them looks at yours valves also. its sucks that a timing belt in hondas is such a pain and costly.
i got valves adjusted
water pump and timing belt cost be about 700
Old Mar 2, 2009
04 Honda Civic's Avatar
damn thats alot I would say, normally $500 is what is expected at a dealership, or at least I thought. I will be doing mine this summer or sooner.
Old Mar 2, 2009
speedfoos's Avatar
That sucks. I charge $100 +parts to do them in my garage.
Old Mar 2, 2009
$100 bux wow thats great..parts are only about $200 so $100 for just labor is like $300. I think the stealerships charge $300 for just labor
Old Mar 2, 2009
I think valve adjustment is also included with timing belt replacement. They did the tensioner too I would assume?
Old Mar 3, 2009
Sluggo's Avatar
Sluggo is an unknown quantity at this point
Want to hear something crazy?... my brother has a 1990 Accord that he put 435 thousand miles on it.. he finally gave it to charity and got a tax break. the car was so good, he bought another honda...a 00 civic, he put 236 thousand miles on it.. BOTH cars, he has NEVER changed the timing belts, even though his mechanic told him to every time he took it in....
Just shows honda quality... at my last job, my friend has a Hyundai.. he never changed his timing belt.. at 106 thousand miles, it broke... and he needed a new engine. I would not suggest doing what my brother did... but this shows, Honda has awesome cars !!
Old Mar 3, 2009
yea its all a hit or miss..where do u live sluggo?
Old Mar 3, 2009
Krumenager's Avatar
Krumenager is an unknown quantity at this point
Are there any symptoms before the timing belt goes?
Old Mar 3, 2009
speedfoos's Avatar
Nope. It either works and your motor is fine, or it breaks and you bend valves. There are no in-between stages.
Old Mar 4, 2009
Sluggo's Avatar
i live in Arizona.. but my brother who i am talking about lives in California. Around the Santa Maria area
Old Mar 4, 2009
What if the belt was to stretch a bit could u somehow have a rough idle?
I was reading in the owner manual and it says 110k or 7 years whatever comes first so remember dont always go according to miles.
Old Mar 4, 2009
dopes6070's Avatar
dopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond reputedopes6070 has a reputation beyond repute
Just to give you a heads up I would tell them NOT to change the water pump, tensioner and not to adjust the valves since you only have 10k miles. Replace only the belt since its the only item that will go bad with age. I work on these all the time and under your circumstances I would want get some more use out of the water pump/ tensioner. Definatly have the coolant flushed though.
Old Jun 22, 2010
Many thanks everybody.
I decided to replace the belt but have serious doubts about the age of the new one I buy, considering that Honda changed to timing chains instead of belts some years ago, and those in stock may be about as old as the one in my car. Or is this a dumb question (the belt in storage will last much longer, maybe ?)
Any help will be very useful.
Old Jun 23, 2010
BlueEM2's Avatar
Whachya lookin at?
Wow your still debating this from 2009? Honda still manufactures new replacement belts for your car. So your getting a new belt
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
mattdoc
Mar 14, 2017 12:10 PM
ChristinaVHH
May 10, 2015 03:51 PM
dano2005
Apr 14, 2015 01:58 AM
