1996 honda civic ex with 5spd swap
ok i bought a 1996 honda civic 2dr ex coupe with a bad motor i replacing thr motor monday. and the car has been swapped over to a 5spd before i got it
question is the motor i got is coming from a 1997 civic ex auto car will there be cels as far as useing the auto harness and auto ecu
Re: 1996 honda civic ex with 5spd swap
Umm, if you leave the wiring the same as it is now (if you don't get CEL's) then you won't get them after the swap. You are only changing the engine, correct?
jessicakaybby
Apr 20, 2015 12:11 PM
