Civic seat foam any aval?
Re: Civic seat foam any aval?
junkyard it up <3 them...if u dont mind a piece of a car that multiple people have farted on. but yeah check a junkyard bring a box cutter, they might charge u like 2 bucks for it and another like 1-3 to get in or bitch at you for ruining a seat. if not buy a block a tempurpedic foam and make your own custom seat cushion like ish from pimp my ride, now you can jump on your seats and YOUR WINE WILL NOT SPILL.
i haven't tried a local yard currently it's -8 w/ a windchill of -30 degrees. the bone yard is where i found my last set. i actually used a passenger side, since they are used the least.
they have expanding foam in a can but it may actually be too firm. it might work tho as a solution. check the hardware store insulation aisles. i used it a while back you spray it out, then once it dries it turns into very dense foam.
mistermenphis22
Apr 3, 2016 08:06 AM
