foglight switch is receiving power but fogs dont turn on..
Old Jan 14, 2009
TOEnail's Avatar
TOEnail is a jewel in the roughTOEnail is a jewel in the roughTOEnail is a jewel in the roughTOEnail is a jewel in the rough
as title says...
i also had to splice some hook up wire to everything because the harness came up short. im not sure if thats the problem.
Old Jan 14, 2009
sl33pyriceboi's Avatar
Re: foglight switch is receiving power but fogs dont turn on..
thats really little info for us to work with. why do u explain what and how you did ur wirng harness and how u hooked it up. if you post up some pixs we could probably help you a lil more
Old Jan 14, 2009
TOEnail's Avatar
Those two plugs you were wondering about connects to the fuse compartment. Here's what he sent me...
1st Step: Locate the fuse compartment under the steering wheel
2md step: insert the two plugs to the inlet (you can see in the picture where the red wire goes and where the white wire goes. and BTW, the plugs are already insrted.) and ground the harness
3rd step: put the cover back up and viola! your done
This is exactly what he sent me. Try it out and see if it works.
my guess is probably how i extended my wires. i bought some hook up wires and wire crimps from radio shack and extended all the connectors. the hook up wires look like they barely do much.
im about to just call it quits and splice em to my parking lights.
Old Jan 14, 2009
qijian's Avatar
recheck the whole wiring and make sure everything fits perfect. then make a go for it again. gl bro
are u sure the new wiring u added is the right size?
Old Jan 15, 2009
TOEnail's Avatar
probably not, but if it isnt, i don't think the switch would be getting power.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
alexkharden
Apr 23, 2015 07:13 PM
SSMatey
Apr 13, 2015 06:09 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
klam
Nov 16, 2001 03:36 PM
