kinda of a big problem
Old Jan 8, 2009
01candycivic's Avatar
01candycivic is a jewel in the rough01candycivic is a jewel in the rough01candycivic is a jewel in the rough
ok i go through new batterys like it's candy. I dont drive the car so it sits up, my problem is i left the car with the new battery hooked up mon. and now i try to go start it fri and the damn thing is dead. the weather has been right about in the 50's. does your battery really die that fast if you dont drive it??? or could my car some how be drawing power from somewhere?
Old Jan 8, 2009
SITNLOW97's Avatar
SITNLOW97 will become famous soon enough
Re: kinda of a big problem
Hate to say it but its gotta have a draw somewhere..
Old Jan 8, 2009
EM2MAGMET914's Avatar
EM2MAGMET914 can only hope to improve
wow same thing has bin happening to me do u have any added accessories like accent lighting, gauges, etc anything tht could draw even minimal power thts not factory installed?? my footwell lights used to draw power cuz they would dim but stay on n it would kill my battery i couldnt tell during the day so my batt would die...id say chek anything u have installed like tht...
Old Jan 8, 2009
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
is your trunk or dome light on? that will drain it.
usualy with evreyting closed up and evreyting off the nominal "parasidic draw" of the battery should be ~50ma. thats .05 of an amp.
find the amp hour of your battery (stock is 47AH) and do the math. u got a 1 amp draw the battery should last at least 47 hours or almost 2 days.
at the above parasidic draw the battery will last 940 hours or 39.16 days.
Old Jan 8, 2009
well i have hids, and i dont know if my trunk lights even come on there is no lights back there cause i shaved trunk.! ill check wheni go home and charge the batttery.
Old Jan 8, 2009
kcari's Avatar
if im moderately playing my headunit with a lot of LED light displays on all 4 speakers (amp off) without the engine on, how long do i have until the battery dies?
Old Jan 8, 2009
Keepitmovin's Avatar
Keepitmovin is an unknown quantity at this point
Do you have an alarm? The flashing security light has enough drain to kill the battery on my jetta in a week.
Old Jan 8, 2009
kcari's Avatar
really? 1 LED shouldnt make that big of a difference?
Old Jan 8, 2009
i do but it been on there sence 2002. i had it sitting for two months one yeah and it started right up
Old Jan 8, 2009
There are two led's, driver and passenger door but thats what I thought too.I've left the battery connected twice now and went out of town.First time was 10 days second time 7 and she was dead when i got back both times.Keep in mind Im assuming it was the lights I could be wrong and just have a similar problem.
Old Jan 8, 2009
kcari's Avatar
so did u just charge it back up and it worked like new again?
Old Jan 9, 2009
manahoonie's Avatar
at our Mazda-Subaru dealership, the Mazda Mazda6 cars die off on a weekly basis... well, with the amount of cars we have there, we're probably charging the batteries in the cars once every two weeks...and that's just unlocking and locking the cars up each day....even WITh the occasional lot party (rearrange the cars, so the cars are running then)
Old Jan 9, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
you have a short somewhere that is draining power from the battery while the car is off. those are hard to find man, i suggest calling up an electrician or a good local shop.
Old Jan 9, 2009
twitchit's Avatar
twitchit is an unknown quantity at this point
Something's definitely drawing off your battery...do you have a multimeter?
Old Jan 10, 2009
electric130's Avatar
i've had my car sitting for 8 weeks with the alarm LED flashing while i was deployed and my car started right up. i'd say you've got something else drawing power. not even a superflux LED would draw enough to kill a battery in a week. multiples? maybe, but you'd have to have about 10 superflux's on. regular LED's? probably 30 or more.
Old Jan 10, 2009
that's not normal for a battery. glad i didn't buy that 6 a few months ago when i was looking......
Old Jan 10, 2009
DieMaster's Avatar
IDK how many amps are u drawing form it?
Old Jan 10, 2009
kcari's Avatar
how do i know how many amps?
Old Jan 11, 2009
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
my car pretty much does the same thing but i also have a little 11.5lb dry cell. as long as i start the car once a week it's fine, and this is in 20-30 degree temps.
Old Jan 20, 2009
damn i have to do some more work then.... well i just changed all the wiring harnesses in the car so i have no idea where to start.......sh@t
Old Jan 20, 2009
TemjinX2's Avatar
i would check your alternator as well.
Old Jan 20, 2009
its new, i just changed that out when i rebilt my motor.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
beveragemp
May 25, 2015 07:11 PM
pincookie1
May 4, 2015 12:22 PM
bsmiley
Apr 27, 2015 01:27 PM
civicPRODIGY
Nov 12, 2001 09:32 PM
