alpine type R's installation
Old Dec 29, 2008
d_lo77's Avatar
d_lo77 is an unknown quantity at this point
just got brand new SPR-69C and SPR-17C speakers for my 02 coupe for christmas. will they fit perfectly in my car with no modification? do i need to use the spacers that are included in the box? also, do i need to disconnect the stock tweeters in the sail panel when install these speakers?
Old Dec 29, 2008
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Re: alpine type R's installation
The 6x9s will fit with a 1/2" spacer. The 6 1/2s will be a bitch to fit in. I would get the 5 1/4s and then you still need a 1/2" spacer.
You may want to consider trading the 6 1/2s for a different brand. I love alpine, got a full setup, but other 5 1/4s will fit much easier.
Old Dec 29, 2008
electric130's Avatar
what's the depth on the 6.5's? check my DIY thread for the fronts.
Old Dec 29, 2008
EnvyX's Avatar
EnvyX will become famous soon enough
i fitted those 6.5"s in on mine. itll go. just wiggle it and use the provided spacer. also, you dont need to disconnect the tweeter.♦
Old Dec 29, 2008
d_lo77's Avatar
thank you ppl for the help. i really hope i dun have to get 5 1/4's instead..
electric130 the mountin depth is 2-5/16" im not sure how thick the provided spacer is tho
Old Dec 29, 2008
d_lo77's Avatar
the box says that it is recommended to disconnect the stock tweeter if it is connected in parallel with the speaker.. but there were no problems when u connected urs? but either way i was hopin to hear that it fits and i did.. lol thanks EnvyX.
Old Dec 29, 2008
if you use the normal spacer that crutchfield sends (or the equivalent) it's a 1" spacer and you should be fine. you'd probably be fine with the 3/4" spacer that i made in my DIY thread.
Old Jan 1, 2009
d_lo77's Avatar
i just installed all 4 speakers today. the fronts i used the provided spacer made especially for honda's but it still wouldnt fit in properly. i tried wiggling the speaker in but i couldnt get all 4 mountin holes lined up. instead of forcing it in i had to make the hole bigger in the door so the back of the speaker would fit in easily.
the rears would fit in but it would almost touch the trunk springs so i just used the provided spacer to be safe. i didnt have time to put the rear shelf back on to see if theres clearance on the speaker but im pretty positive it should be ok.
just heads up to other people who want to get these speakers
Jeffdp
Aug 5, 2015 11:38 AM
97-DX-Lover
Jun 14, 2015 06:07 PM
sjonesd3
Jun 11, 2015 06:32 PM
carid
Jun 10, 2015 09:57 AM
