Popping noise when I turn my car
Old Dec 12, 2008
mdawg's Avatar
mdawg is on a distinguished road
Anytime Im making a sharp turn or pulling out of a parking lot and turn left or right my wheels make this weird popping noise?? My dad said it may be a busted boot or something? This a easy fix or not?
Old Dec 12, 2008
99WhiteJDM's Avatar
99WhiteJDM will become famous soon enough99WhiteJDM will become famous soon enough
Re: Popping noise when I turn my car
CV axle boot/joints could be a couple of things. I've never messed with them. I just get a shop to replace them. From what I hear your better off replacing them instead of rebuilding them. I think what happens is the grease comes out of them and the friction makes them pop. I also think if you don't have the money to replace them right away you could not put power to them when you turn. I know when mine did that on my CRX a long time ago, I would just coast thru the turns and give it gas when the wheels were straight.
Old Dec 12, 2008
check under the car. if the axle shaft boots look torn and greasy, theres the problem. otherwise it could be bad strut mount bearings or top mounts. or a whole lot of other things.
Old Dec 19, 2008
sql_civic's Avatar
It's not hard to replace the acxle yourself. I recommend reman Carquest axles for about $65 each with a lifetime warranty. I've done about 8 of them over the years on various cars.
Old Dec 21, 2008
lilmidget08's Avatar
lilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond reputelilmidget08 has a reputation beyond repute
about 99 percent sure its your axles even if the boot isnt ripped open they could still be making noise. but if they are ripped open then drifnately wanna replace them. its a piece of cake to do
Old Dec 21, 2008
Chronic Nate's Avatar
Chronic Nate is an unknown quantity at this point
do u have an aftermarket lsd? my kazz 2 way adjustable clicks in the turns cuz its on full lock. But i just coast through the hard turns and give it gas in the staights.
Old Dec 22, 2008
mdawg's Avatar
No, and whats the way to go about checking really if its the axel.
Old Dec 22, 2008
sql_civic's Avatar
Inspect the boot - if it's ripped replace the axle. Jack up the car and turn the wheels all the way left and rotate the wheel by hand and listen. Try the same but this time turned to the right.
Old Dec 23, 2008
e-z's Avatar
e-z
e-z is an unknown quantity at this point
yeah axels. if the boot is just torn you can sometimes just buy a new boot for like $15, but you say yours is popping so u might have to replace the axles. its not too hard to take them off. u just have to have the right tools. u need a huge socket like a 20 or 22 cant really remember. but if you have basic mechanical knowledge u should be able to do it yourself
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
cdt12271
Apr 23, 2015 11:36 AM
SSMatey
Apr 13, 2015 06:09 PM
Russps
Nov 8, 2001 02:00 AM
