Reseting the Maint Required light
Old Dec 9, 2008
SalvageRedo's Avatar
SalvageRedo is an unknown quantity at this point
I didn't find this on here so thought I would post a helpful tidbit. Recently my Civic threw a couple Codes my way. O2 sensor and IAT sensor. I replaced them and the light center Maint Required light didnt go off. I unhooked the Neg terminal and pulled the #6 ECM fuse for 2 minutes. The Maint Required light was still on. I went to my shop class to see if it was still throwing the same codes or different ones. After running the OBDII scanner... it wasnt throwing [any codes! WTF?!
Apparently if you 1) Turn off the car 2) Push and hold the odometer/tripometer button (the one on the right) 3) Turn the ignition to on (don't start the car) 4) Continue to hold the button for about 10-15 secs, it will reset the light!
If something is still wrong it will light up again, but if for some reason it doesnt want to turn off and there is nothing wrong then this will save you from wondering what's making your baby sick.
Old Dec 9, 2008
Albertross's Avatar
Member
Albertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond reputeAlbertross has a reputation beyond repute
Re: Reseting the Maint Required light
Maintenance required light will show up every 4k-5k miles, I forget what the interval was. It won't light up "if something is still wrong", that's what your CEL is for. the MRL is there to remind you to do an oil change, lol.
Old Dec 9, 2008
I didnt know that. But it was the only thing illuminated when I found the 2 codes P0113 and P0132. Thanks for the info though
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Blazz
May 25, 2015 10:56 PM
Blk01Cpe
Dec 13, 2001 08:34 AM
TropiKalCiviC
Nov 8, 2001 10:13 PM
